- Feb 7, 2024
- Age
- 70
- Mannum South Australia
- MG4
Not in the slightestHow does V2G help an off-grid system?
T1 Terry
What does the G in V2G stand for?V2G is essentially rapid charging in reverse and requires an external, bidirectional EVSE.
Isn’t an off-grid system basically its own little “grid”? I guess V2H would be more accurate for an off-grid system then, regardless, the MG4 still doesn’t provide this.How does V2G help an off-grid system?
No. A grid-tied inverter or V2G system requires a grid connection to be operational and they will intentionally disconnect if the grid is disconnected.Isn’t an off-grid system basically its own little “grid”?
would you need a grid connection for bidirectional charging though? I just don’t think the MG4 V2L is a robust enough system for an off-grid system, not robust enough to recommend someone buying it for that purpose anyway.No. A grid-tied inverter or V2G system requires a grid connection to be operational and they will intentionally disconnect if the grid is disconnected.
No, but you’ll need a very ‘beefy’ off-grid setup to be able to power a standard EVSE, never mind a rapid charger.would you need a grid connection for bidirectional charging though?
Agreed, it was never designed for that purpose, but it’s very useful to support the house battery in case of an extended power outage, (post #10)I just don’t think the MG4 V2L is a robust enough system for an off-grid system, not robust enough to recommend someone buying it for that purpose anyway.
As an occasional source of power to supplementary charge a home battery during a long grid outage it's perfectly fine.would you need a grid connection for bidirectional charging though? I just don’t think the MG4 V2L is a robust enough system for an off-grid system, not robust enough to recommend someone buying it for that purpose anyway.
That will depend on the system.would you need a grid connection for bidirectional charging though?
The only time the grid supplier can demand access, is when you use the home battery subsidy scheme ...... no such thing as a free lunch or money for nothing, or any truth in the term, "I'm from the govt and here to help you".G = Grid
Means the grid operators have full access to your battery at DC levels.
I guess our time on the road will test this theory out. We plan to use it every time we free camp, can't see the difference between 7kw ac charging each day and 7kw AC discharging each day, it's just the same system operating in reverse. Easier on the battery because the discharge is limited to a max of 7kw, less than a 7.5% load on an SR 51 kw LFP battery, that is extremely light throttle drivingwould you need a grid connection for bidirectional charging though? I just don’t think the MG4 V2L is a robust enough system for an off-grid system, not robust enough to recommend someone buying it for that purpose anyway.
Sure it has been demonstrated as working and @Stageshoot powered his whole house using that configuration (V2L Test. 7kW output...)There was a thread about 18 months ago when someone tested the V2L capacity and got the full 32 Amps (7.4 kW) discharge fine
LOL - had to look that one up!Pat Malone
I'd prefer a 15 A option, just a bit more flexible. Can still plug regular plugs into it, but I also have an excellent 15 A extension cables with 2.5 mm^2 wire.Not long after I got the adapter it was taken off the market & replaced with a 15 amp version.
So only 30 amps @ 220vac ...... I feel cheatedBear in mind that the OBC on the 51 (at least - probably also applies to the single phase 64) is rated to 6.6kW and not 7 or 7.4kW.![]()
