Alb
Moderator
- May 11, 2021
- Solutions
- 6
- Gloucestershire driving an MGS5 LR Trophy
The car may give you enough data to enable a manual adjustment of your figures.
Kent is awful for mobile signal.I live near Leeds Castle in Kent and have exactly the same issues with mobile single at home
Hmm.. the suicide cable!In the meantime, I am using V2L to run a cable into the house, which is fine to power a few essentials (router being top of the list) but I’d really like to power the house before evening sets in.
I thought in my innocence and ignorance that all I needed was a cable with a male 13A at each end, and I could just plug it in to a socket, and Bob would be my uncle, but that doesn’t work.
Does anyone know?
Just to expand on @Ian Key's point.. connecting your V2L to the house, whilst the house is connected to the grid will most likely destroy your vehicles DC to AC inverter immediately.and also how successful was it as a supply of mains power for the house. (kettle, lights etc)
You can't use it as an alternative power supply the house unless you isolate the house from the grid.
And the onboard charger/converter is bidirectional, so will output 6kW+ if the V2L cable/plug has an appropriate resistor value...
I'll give my 2p worth, though please note I'm not a Part-P qualified sparky.Does anyone know if having the boiler electrics supplied via a free plug is allowable? I assume earthing requirements would have to be met somehow, but other than that?
Personally, I’ve done it a couple of times and I was powering the whole house — so, for example, the fridge and other always-on appliances, plus the air conditioner since it was the middle of summer and really hot. Only the last time I tried it didn’t work, because the car cut the voltage as soon as I connected it to the house. I don’t know if this is due to some update that added a new safety feature, but the car didn’t show any errors, and all the previous times it had worked without issues.I have a power cut which means that UK power networks have to dig up the road in front of my house, it might take a day or two.
Given that I can isolate the national grid using the circuit breakers in the meter cabinet (it's actually self isolating at the moment, anyway!), is there any way of plugging the car into the house, just to get the lighting circuits working and to enable me to start up the gas boiler?
At the moment I have no light, no hot water, nothing, it would be great if I could somehow plug the V2L into the house, is that possible as a short term non-electrician exercise?
I suspect it's because the MG's V2L is expecting to supply power to isolated loads, not to a system with a main earth - neutral link.Personally, I’ve done it a couple of times and I was powering the whole house — so, for example, the fridge and other always-on appliances, plus the air conditioner since it was the middle of summer and really hot. Only the last time I tried it didn’t work, because the car cut the voltage as soon as I connected it to the house. I don’t know if this is due to some update that added a new safety feature, but the car didn’t show any errors, and all the previous times it had worked without issues.
That would not resolve the MEN link issue, it will likely still cause a fault and the car will shut down the discharge session.In conversation with the guys from UK Power, apparently the trick is to switch off the main circuit breaker in the consumer unit and then plug the feed from the car in and it all should just work.
I don't know about a next time but it might be your last time. It's called a suicide cord for a reason.though I do now have the male to male 13A plugs ready for next time, if there is to be a next time.
100% this ^^^If you want to use the MG4's V2L as a supply of emergency power, then use a good quality extension cord and plug in your devices directly to the car's V2L outlet/adapter.
