Apple Car Play issue (USB-c connector)
Hannah
Bradford UK
I’ve recently got a new iPhone (16 Pro Max) and Apple CarPlay won’t connect. The phone charges so the wire works (I’ve also tried 2 different wires), but CarPlay doesn’t work. It worked fine with my old iPhone so I’m not sure what the problem is!
Are you plugging into the correct USB? Has to be the USB A socket
Had a similar problem with another usb-a to usb-c cable recently and an iPhone 16 max pro.
Cable was data and power capable but a bit thin and not Apple Original. Will try again soon with other cables.
Having the same challenge - see the compatibility notes on apple.com
We are taking about the iPhone 16 here which has a USBC port, not lightning .
Do you mind changing the title of this thread to be more specific to iPhones with usb-c connectors?
Make sure you have carplay activated under the new phone settings?
Just tried my iPhone 16 with an USB-A to USB-C cable - worked for me. Unfortunately the cable is unbranded - but I think it was an Anker brand bought from Amazon
If your problem is hardware (length or quality of cable), using a small non powered USB hub has been known to help a few people. Worth trying if you already have one.
Just tried this and still not working 😢 the phone is charging so the wire works so I just don’t understand why it won’t connect to Carplay
Without wishing to resurrect the 'holy wars' of CarPlay connectivity & cable choice - you do need to ensure the cable you are using is capable of data. Not just power/ charging. Cable should have a specification / claim that it meets USB 3.0 standards
Mine did'nt connect yesterday .... I got a message on my Iphone saying "unlock the Iphone to connect". Just a thought for you to check.
I've also found that sometimes I need to wait for the car to fully boot up its software and press the brake to get into "ready" mode before I plug in the Iphone and get a connection.
Also I have a pack of these adaptors (USB A to C) :-
I think this was it!! Tried a proper Apple wire and it’s worked. Thank you so much!
Several people have installed wireless adapters, set with a 30s or so start-up delay, and use that for AA/CP (as applicable - mine is AA). Works really well. If I need to also charge my phone I simply plug it in to a cable connected to a USB adapter fitted into the 12V socket. (Which gives a much higher charging rate than that available via the USB A socket). :)
Can I ask which wireless adaptor did you go for.
I had the same issue at first, turns out you can't use the USB-C for Carplay, you have to use the USB-A slot.
What was funny is that it still didn't work with an official Apple cable, had to buy a cheap one off Amazon before it worked!
    Votes: 1,052 77.9%
    Votes: 204 15.1%
