siteguru
Distinguished Member
- Sep 3, 2022
- Solutions
- 3
- Strathaven (SE SR MY22)
- MG4 (2022-2025)
Does it not trigger the screens to go into night mode?I haven't yet been in the position of actually driving the car as it has got dusk. Both times I've been out as late as ten the car was parked up as dusk started to fall and it was already dim enough for the lights to come on when I got back to it. I'll be interested to see at what time the sensor actually decides to turn the lights on when I'm driving!
As far as I remember, there was no clear indication inside the car as to whether the lights were on, in my old Golf. Maybe the central console lit up, but that itself wasn't that obvious. There was no clear "lights-on" indication as there is with the MG4. This had its problems. A couple of times a car mechanic left the lights switch on manual and when I got the car back and didn't notice, I parked up then returned to a car with a completely flat battery! So I appreciate the MG4's clear indication that the lights are actually on.
I have wondered if the MG4 isn't the only car to have this issue, as I have seen other cars with very obvious lights showing in shady places during the day. But the one I really looked at, a car that I turned out in front of in a tree-lined road, turned out just to be very obvious DRLs, as the lights were still on and looked the same once we had driven out of the trees and back under a wide sky.
It would just allow you to monitor the lights on/off state easily.I suppose it will if you have that set to auto. I haven't had it on auto. The way it's been behaving I wasn't even going there. Maybe I'll shift to auto now the problem is fixed.
Yep that's exactly what I thought too. But I didn't like to leave it uncovered completely from a looks point of view so that's why I ended up with my current setup. I have noticed the lights come on within a couple of seconds of going through a darker area but take at least 8 to 10 seconds to turn off when you come back into the light. I have also been observing other makes of car and TBH , my set up at the moment is pretty much the same as other cars for switching on but other makes seem to turn off quicker. So conclusion, it's better than it was before I altered it but still not where I'd like it to be , but it'll have to do , only other way is manual switching.OK, this is a pain. After I typed the previous post I went out, and the lights came on when I drove along a tree-lined road, even with the new sensor cover. It's better, but it's certainly not right.
I went back and did some experimenting. The lights behaved as they should with no cover at all. As soon as I put the new cover back, parked in the shade, they came on. Took it off, and they went off. Prised off the transparent plastic I'd used to cover the holes in the new cover and put it back. Lights came on. It was almost instantaneous, too. No wait to see if this was just a temporary shadow, bang the lights went on. I didn't time how long it took for them to go off after I took the cover back off again but three or four seconds maybe. When I drove the length of the avenue and back the lights stayed off, with no cover at all. (Other cars
It seems this sensor only works correctly when it's pretty much unshaded by anything.
What next? I think I'm going to leave the cover off completely for a few days to see how it performs. But that's not even a medium-term solution. Any suggestions? I think it needs a completely transparent cover.
Mine has been OK so far - but maybe I haven't driven anywhere that would be shaded enough to fool the sensor.
If you can draw round the base of the cover and send me the sketch, I'd be happy make you a clear cover from Acrylic.OK, this is a pain. After I typed the previous post I went out, and the lights came on when I drove along a tree-lined road, even with the new sensor cover. It's better, but it's certainly not right.
I went back and did some experimenting. The lights behaved as they should with no cover at all. As soon as I put the new cover back, parked in the shade, they came on. Took it off, and they went off. Prised off the transparent plastic I'd used to cover the holes in the new cover and put it back. Lights came on. It was almost instantaneous, too. No wait to see if this was just a temporary shadow, bang the lights went on. I didn't time how long it took for them to go off after I took the cover back off again but three or four seconds maybe. When I drove the length of the avenue and back the lights stayed off, with no cover at all. (Other cars' lights were not coming on.)
The offer is there if you need one making.I think you'd need the actual cover, although that could be arranged. The way it slots into position is quite important and just drawing round the base wouldn't show that.
Someone else mentioned 3D printing the version on the file that doesn't have any holes, but doing it in a transparent material. It would still have to be heat-proof though.
Would you be making this by laser cutting the acrylic to match the shape of the hole as such, or can you manipulate it / mould it as suchThe offer is there if you need one making.
Yeah, I found even fitting a bit of perspex over the open hole triggered unwanted lights on episodes again.
So I figure bollox to it, it can't be seen unless you peer through the windscreen so I've left it open, I'm sure the sensor can deal with a little dust.
Its pretty good now I find, never comes on in sunlight as before, only when rain is threatening and it's pretty overcast, so fair enough I guess![]()
I’d say that one should be fine. If I recall correctly, @Macadoodle found when drilling a hole in the original cover, that it had to be in the perfect spot, otherwise it didn’t work as planned, so it may be the case that the one you have now has a line that covers a crucial area.I'm thinking about this post here, where the poster said even perspex over the hole was causing the lights to come on again.
I'm wondering if anyone has tried the most open of the designs from Pliskin's file, and whether that works (with or without a transparent cover).
It may be that the cross-hatching on the one I have is holding back too much light, but that light from the side isn't needed to get it to work correctly. If this design works as well as the naked senson does, it just becomes a question of finding a suitable dustproof cover for it.
