fred12345
Thanks for detailed post. I charged mine to 100% quite a few times from various percentages and from what I can see, there is always balancing at the end when the charge reduces from 3kW (granny charger) towards 1kW or less for random amounts of time, sometimes 15 min, sometimes much longer. I can only assume it's doing the balancing... Mine is 2022 standard range MK2 model...Ok, so this is getting to be an older thread now but I did say I'd come back to you all with more info about my NMC battery equalisation experiences.
Firstly, I can say quite categorically that my ZS EV does not equalise it's battery at anytime if the slow charge is started & the 'low battery' warning has not been given. It is imperative that the low battery warning has been given first prior to charging as per the owners manual for the MK2's. This ensures the cars battery management system takes full control of the whole charge. Smart charging (eg: Octopus Energy IG) should be turned off to avoid the network pausing the charge which can stop the equalisation from happening even when it resumes. The charge must not be interrupted. On the facelift MK2 EV's low soc warning is at 20%.To be sure all battery cells are below the 20% soc level I've found it best to go to 17 or 18% before charging.
I have found that equalisation charging at 100% takes around 12-15mins. During that time the charge rate drops progressively from 7.1kw to eventually 200w & 100w. After that my full range seems improved a little & the GOM certainly seems more accurate. The car shows routinely 325-329+ miles after the equalisation in eco mode. Eco being the mode all manufacturers show their range in. My actual range last week in eco mode showed an easy 279miles. Running the battery down to 10%, if I had done that, would have given me just a bit under the lower gom figure probably at around 305 miles. So that is an extrapolated figure.
So, I still don't understand why some people on here are saying they can equalise at any state of charge. Mine won't & neither will my friends ZS MK2 EV. I'm guessing software has changed. Anyway, that is my experience which is as the owners manual says.
