Bluetooth not working and my dealer doesn't care.
GameZone
Norway
My Bluetooth is constantly disconnecting after a few days, so I went to my dealer and waited two months for them to look at my car in order to solve the issue.
When I picked up my car, they just handed me instructions on how to connect the ismart app. I asked if they updated my infotainment from R46 to the latest, but told me I had the latest update. I told them that there there are newer software updates available, but after having caught their lie, they just gave me a story regarding MG4's bluetooth not working with newer iPhones, and they don't know when it will be solved. He also told me that a new software update won't solve the issue, and that I would have to pay for it myself.
Thanks MG. Not to mention that I bought the car when it was advertised as having 4G and wifi update capability.
When I picked up my car, they just handed me instructions on how to connect the ismart app. I asked if they updated my infotainment from R46 to the latest, but told me I had the latest update. I told them that there there are newer software updates available, but after having caught their lie, they just gave me a story regarding MG4's bluetooth not working with newer iPhone's, and they don't know when it will be solved. He also told me that a new software update won't solve the issue, and that I would have to pay for it myself.
Thanks MG. Not to mention that I bought the car when it was advertised as having 4G and wifi upate capability.
Unfortunately it's a well known fault - see the Software Update thread.
I hoped that the latest software would fix it, so managed to get my dealer to install updates under warranty. I now have everything up to date except the T-Box software, and it still does it.
It seems to be random - mine has connected every time for about a week until today, when I had to re-pair it three times in one day!
Maybe you need them to prove that to you
When I first got the car I had an iPhone 11 and now I have a 16 Pro, the car is running R40 software and if anything the phone connection is more stable on the newer model.
I would suggest they are talking out of their < insert appropriate part of the anatomy >
I complained directly to MG. Today I received a phone call from my dealer, telling me that will give me the update after all 😂
Mine has now stopped working all together!
It connected every day without any pairing requests for a week up until last Thursday; then I had to pair 3 times in one day, and subsequently it refused to connect to anything since Friday.
When I set it to search now it doesn't see any bluetooth phones or tablets, whether Android or Apple; the only devices it finds are a couple of neighbours' TVs.
I'm not convinced it's a software fault, the symptoms could point to hardware. Either way, it's back to the dealer, I guess.
Have you deleted the car's Bluetooth history?
As I have said before, when my car declares it needs to pair with my phone again I ignore it and plug in to start Android Auto. It then pairs automatically using the previous credentials. It then continues connecting without AA for a few weeks. I just repeat as required.
When it happens, there is no Bluetooth history on the car! Every time it decides to send a new pairing request, mine "forgets" all previous connections, and shows no history.
However, I have got it working again, so won't be heading back to the dealer, for now at least. If it helps anyone else with this issue, this is the sequence of events I've experienced with Bluetooth pairing:
The car paired OK with my Android phone from new in September. The first re-pairing request came a few weeks later; thereafter it would need to be done every few days, and every time the car would recognise my phone (to issue the pairing request) but show "no pairing history".
Then it got to the point of the car frequently not connecting, but also not issuing pairing requests unless I set it to search for my phone.
Eventually I got the dealer to update the software under warranty to correct this and some other faults. FICM was brought up to MPU 1300r63 and MCU 68.4.7.0 but TBOX wasn't updated from SNAKP21E32.
After this, Bluetooth reverted to the original status where it would work for several days in a row, then issue a new pairing request and need to be paired again. As others have said, the phone will show lots of saved connections to the car, but the car shows no pairing history. All the old connections in the phone can safely be deleted, because none of them will work again when it is re-paired with the car.
A week or so ago Bluetooth stopped working with my phone altogether; there were no pairing requests, there was no pairing history, and when I set the car to search it couldn't "see" any BT devices except a couple of nearby TVs (I tried Android and Apple phones and tablets and it found none of them, and no nearby cars etc, just the two TVs)
I then tried doing a Factory Reset on the Infotainment module; this made no difference, so I decided a warranty visit would be necessary.
( NB - I don't recommend a Factory Reset, because you then have to re-do every setting you have ever changed in the car, including the satnav, radio, online music, wifi, iSmart, etc - I still haven't got everything back the way it was before)
Today, prior to contacting the dealer, I was looking for the BT MAC address in the Engineering menu, where I noticed an On-Off switch for Bluetooth. It was On, so I switched it Off. I then exited the Engineering menu, went to the normal Phone screen, where I switched Bluetooth back On. Lo and behold, it is fully operational again (for now, I'm not confident it will be a permanent fix).
So, if you have the same problem, try switching Bluetooth Off and On again!
I'm guessing that the BT On-Off switch is for the BT module in the TBOX, whereas the Factory Reset option is for the FICM only.
That's what I do when it stops connecting automatically. It was annoying at first, before I discovered that workaround and I thought it is completely broken, but then it became "Oh ok...so it'll be like that" 🤷‍♂️
Recently I drove a Seat Ibiza (petrol) and oh what joy after the initial set up and pairing my phone Car Play app connected automatically via bluetooth. No need for cable from phone to car USB C port. Why on earth cant my MG4 Trophy do the same?
Yeh, but did it have, Character? 😉🙂👍
I'm currently in a courtesy car MG4 from the dealer and BT connects every time and I never manually paired it with this car :ROFLMAO: :unsure: I can't remember if this was after I plugged in to Android Auto - I think some kind of automatic pairing happens then? I've only plugged AA in once though, and BT continues to connect every time.
I know this is an old thread, but I have a new iPhone and I cannot connect to apple car play or bluetooth. With bluetooth toggled on and off, it cannot find the phone.
Reading above it might be a software issue, however how can I tell what version of the software I have please and can someone tell me the latest? If there is an update I will ask the local dealer to update it.
As an aside , I also cannot connect to Apple Airplay. I just get a message saying connect a cable. Having read numerous forums it might be down to the quality of my cable so i will buy an Apple USB A to C cable first.
So frustrating as you expect a car to connect to bluetooth as standard.
I just bought a cheapo Wireless Carplay Android Auto adapter. Twenty quid ( a certain online jungle based store) has them from ten quid up. No cables faffing about and my Sammy S25Ultra connects to it like a champ. Music and Waze now run flawlessly whilst the phone is either in my pocket or wirelessly charging. It says its compatible with you Apple types too.
Apple CarPlay needs a data cable, not just any cable will do.
I can’t determine whether you have (another) new iPhone or if your are new to iPhone, so I’ll also mention that for the car to be able to see your iPhone you need to be in the Bluetooth menu, otherwise an iPhone will hide itself from other devices.
Generally most people find that CarPlay works better if that is the only connection between your iPhone and the car, having Bluetooth connected as well sometimes forces the CarPlay connection to drop. If you are intent on using CarPlay a lot, buying a wireless dongle can be a worthwhile investment.
Hello
What I learned since 2 years and half with this car : when a Bluetooth issue show up, it's because the car MAC address is changed by itself (IDK why but still trying to figure it out).
How I know that ? Early 2024, 6 month after having the car, I got a Bluetooth issue and after trying reboot or BT off, Reboot and BT on or Reboot + Bluetooth off and on, I learned that it fix BT pairing issues and one time, I went in engineering menu and check BT mac address. The good one starts with CB:.... and I got 73:....
After disable and enable the BT still in engineering menu, the MAC address was restore to the good one. At this time, my car was running SWI68-29958-1300R46.
Late 2024, I got R63 and the paring issue were almost daily. And I check the engineering menu to read the BT MAC address and I got randomly a new one every time.
Sometimes, I accept the new paring request and the car get his former MAC address and my phone connect normally (I got Pixel 7 in 2023, Pixel 8 Pro in late 2024 and Pixel 10 Pro XL since September) but most of time, I have to clear the pairing from my phone and do it again.
As MDWMG said, toggle BT off and on can help but reboot, factory reset don't help for good. The only way is :
Build SWI69 (SE/SE ER/Standard/Comfort) : update MPU to R40 (R42 available too)
Build SWI68 (Trophy/Luxury) : update MPU to R67 (R69 available too)
For other builds, IDK...
And TBOX have nothing to do with BT issues, I got 3 different version SNAKP18E32, SNAKP19E32 and SNAKP23E32 it doen't make any change.
I had the same problem with an mg dealership, I was told it would be updated as I had sensor problems, the sensor problem I believe was actually from the frost however, they said they did an update but didn't, and when I said to them it was the same version they claimed they "reinstalled" the latest version and "updated" the sensors. They clearly did nothing though.
I'm having bluetooth issues, I connect and then after a day or two it loses connection and won't reconnect, I have to 'unpair' and then 're-pair' which is a bit of a faff, is it worth even contacting the dealers?
I'm currently running SWI33, R32
Looking at the post from Mouss it looks like R40/42 (for SE/SE ER/Standard/Comfort) or R67 (R69 available too) for (Trophy/Luxury) is might help.
I am just waiting for Appleplay dongle to arrive.
    Votes: 1,055 77.6%
    Votes: 207 15.2%
    Votes: 99 7.3%
