Can I use this 12V battery on my MG4?
Don't know. Some places say that AGM should be swapped for AGM.
Thanks to Google I found the following....
Can I charge an AGM battery with a regular charger?
AGM batteries don't have nearly as much internal resistance, which is how they absorb 30, 40, even 50 amps at a time instead of a regular battery getting stressed out at more than 10 amps. This is also why an AGM battery needs special charging. Regular battery charging can break AGM batteries.
Looks like you will have to stick to a normal "wet" lead acid battery.
    Votes: 1,031 77.6%
    Votes: 201 15.1%
    Votes: 96 7.2%
