Does anyone know the peak charging current of the 12V battery?
Why bother with anything other than a standard lead acid replacement? The car's charging system is set up for it.
The fact the lead acid battery has such a short life and after 2 yrs, you are at the mercy of the lead acid battery gods, just waiting for a cell to fail .... a 1 in 6 possibility or a battery made as cheap as possible having a cell fail .....
T1 Terry
That's the dumbest thing i've ever heared. Why would you test a sealed battery at the cell terminals, bypassing the BMS? Nobody in practise will do that (why would they, they bought a battery, not a cellpack). So this was demonstration of the sealed product, not the cells themselfs.
Also if you bothered to read the comments, you might have cought this
"Update: just pulled 103Ah by charging to 16V and down to 4V! At least I pulled full capacity. "
So he did the proper test. But do you know of any 12V based inverters that work down to 4V? Most will die at ~10V.
So, that was very helpful to understand how you go about appraising a cell chemistry, not in the slightest, but rather depend on an influencer to push his bias and not bother to look at the information that influencer provided, like 17.2v would be fully 100%, after settling and actually measuring the cell voltages, not what he charged the pack to :mad:
If he bypassed the BMS to get the 16v you say he claims in in the "Update", then doesn't that destroy your opening reply
At least other members will now know how much weight to apply to your battery capability assessments, and you have backed up my warning about drop in batteries
T1 Terry
T1 Terry
Fact of the matter is; batery cant pull it's usable capacity with any of the standard equipment, unless especially designed around it.
The battery in question doesn't even have a properly setup BMS, so me, as an end user will never be able to pull full capacity, regardless of what equipment i have.
And to top it all off, the fundamental issue of charge/discharge efficiency and very wide voltage range (if you want full capacity) still stays.
So in the context of a car battery, this thing is pretty hopeless. You can't use full capacity, because you'll be cutoff at the top AND at the bottom. And i can't image how car's DCDC equipment would handle rough cutoff, if that was set lower than the charging voltage.
So in that regard, it's much worse than LFP.
Honestly, i'd rather trust an "influencer" that has proven to be reliable rather than some forum member, that can only back up it's statements with "i say it's like that so it must be true!"
T1 Terry
Even if that were true (i run a 3 year old battery and it seems to be near perfect) you'd be still better off with an LFP based replacement. It's operating voltage is closer to lead acid, will offer more capacity for a given formfactor and will have plenty charge/discharge power for an EV application (again, it doesn't need to spin up an engine for it to require tons of peak amps).
I really don't understand why you brough Na+ in this discussion.
It could be that I actually work with off grid systems and have done for quite some time. I actually conduct hands on testing rather than form opinions from watching You Tube influencers ......
Knowledge is a two edged sword, a little is far more dangerous than none at all because it makes a person believe they actually know about a topic ......
A very common phrase uttered by many as their learning increases is a quote from Albert Einstein “The more I learn, the more I realize how much I didn't know'.”
T1 Terry
T1 Terry
Exacly. So do i. Plenty of experience with LFPs and other chemistries. It's just a simple fact, that Na+ just isn't ready for primetim, unless you have a very specific application.
Cost isn't an advantage, Wh/kg or Wh/L or equipment compatability neither.
It might be a fun diy project, that doesn't care about cost or longterm viability.
If we go back on topic; OP needs a drop in replacement, not a science course. So it's simple matter of finding a LFP based battery with car terminals, that fits MG4.
LFP and Na batteries have multiple cells that can fail too. Not sure what the number of cells has to do with anything. Same battery gods.
Lead acid is pretty robust, has proven its worth for over a century and if not abused it will last pretty well, and one just needs to swap it out on a reasonable schedule and use a decent brand.
If there is a well made drop in LFP, fine, provided it is set up to handle the charging system of a car expecting to work with a LA battery. Fortunately the voltages are similar enough it can work but the process of charging LFP is a little different as I'm sure you are well aware.
I had fun building a hybrid LFP - SLA battery for my last home - it takes some care to make sure operationally you get it right but it can be done.
Finally - the MG4 constantly gives us battery voltage data so we can readily assess its condition/health.
One of the really neat things about the MG4 (and other EVs) is that the auxiliary battery gets charged not only while driving but also while the car itself is being charged which for most EVs is pretty regularly. It also will use the drive battery to do an interim top up charge if necessary. So the aux battery is looked after pretty well.
Lead acid has worked since it's inception in the 19th century. Built to the quality standards when lead acid was in it's prime, they would last a good 10 yrs.
At todays prices, that would be well over $1,000 and be hand built to be small enough to fit in the same lead acid battery position .... it would a flooded cell and require the same constant attention that such a battery requires to get the full cycle life ...... contaminate the electrolyte with tap water or let the electrolyte level drop to or below the level of the plates ..... there goes your cycle life
The same size no maintenance lead acid AGM battery built to a price as is todays norm. 2 yrs will be close to about it, you are gambling with failure past that point.
A drop in LFP or Na+ battery, with an active balancer and the ability to control the input current to ensure no cell goes over 3.65v ..... unobtainium .......
I can tell you how to build one to fit inside the original battery case and the electronics to mount outside the battery case, so it can ***dissipate any heat generated ....... but I have no plans to go back into the battery building business at the moment .....
T1 Terry
*** Heat generated and trapped inside the battery case will shorten the overall battery cycle life ...... heat kills any type of battery cell because the electrolyte will eventually boil and vent from the cell ..... only a flooded cell lead acid battery has an electrolyte replacement commonly available, pure water .....
You don't need an active balancer or current limiting on the BMS side. A passive balancer is just fine (and is part of most BMSes anyway), as for current limiting; given that LFPs tend to hold their current flat up to ~90-95%, there's no need for that either. You just cut off charging at 3.65V and its going to be fine. Maybe the battery won't be fully charged always, but that's actually a good thing in automotive application.
I think the biggest issue here is cold weather countries. If you're in an area that has regularly temps below freezing and if BMS is properly set, you might end up with a discharged battery eventually, since you can't charge it.
So a heated battery, sane voltage limits and a more relaxed short term discharge current limits would make such battery just fine for an EV application.
There's a chance such battery exists.
I thought the same, get them balanced to start with and a passive balancer would keep them that way ..... By passive, you are of course referring turning a resistor into a heat across that cell if it goes above a nominated voltage, most are set at 3.8v and off at 3.45v.
Even with them mounted on it'd own piece of proper finned heat sink and on the outside of battery, they still got that hot I couldn't touch them.
Even though they were big units, supposed to handle 2 amps, it didn't take long before the first ones failed, turned on but didn't turn off ....
Luckly, the BMS I designed and built, had warns for out of balance between cells and a second unit that did Blue Tooth and over the interweb as well, would send a warning that half the pack voltage was more than 5% out of balance to the other half ..... because the top of the cells were accessible, I could direct the owner on which wires to disconnect and how to put the single cell charger on to bring the cell voltage back up ....
But what about the drop in battery, I know they only use around 5mA load across the resistor as a balancing current capacity draw down ...... but trapped inside that drop in box ..... that heater is mounted to a piece of aluminium, designed to dissipate the heat into the surrounding air ..... but that heat is trapped inside the box, no air movement across the heatsink ..... that voltage sensing circuit relies on a transistor to turn the link to the resistor on or off, and we all know what happens to diodes when exposed to excessive heat .....
Now, there is no warning a cell is dropping voltage in comparison to the others, there is no way to get to the cell wires to disconnect the cell from the balancer and resistor .... the cell just gets pulled low and now has less capacity than the other cells ...... those cells still have the energy to push through the cell that has now dropped to 0V, this is called reverse current flow, instantly that cell dies, killing the whole battery.
The same scenario happens with electric tool batteries, it's only a single cell that went flat and died ..... but the whole battery goes in the bin if you don't know how to repair them.
That was the reason to upgrade to active balancers. Tried the capacitor bank type, maybe ok for 12 mths, if they worked in the first place, but the induction coil balancers seem to work for life ..... although, there are so many copy units sold by every man and his dog, who knows any more.
We used and still use ZHC solar, they have been reliable, just need to ensure some clown, dressed as an auto electrician, doesn't decide he knows all about this stuff, disconnects one of the cables and doesn't immediately wrap it is some form of electrical insulation ..... they can shift 5 amps, but not 100 amps if shorted to ground .....
T1 Terry
    Votes: 1,094 77.8%
    Votes: 211 15.0%
    Votes: 103 7.3%
