Car won’t open and it seems 12v battery is dead
aquib99
manchester
Hello,
I’ve had my mg4 SR for 3 months nearly. I was quite poorly the last two days so never went outside to my car.
Today I tried to open my car with the fob to no response. I tried the manual key entry but that didn’t work either.
I assume the 12v battery died - my question is how do I now charge it? Is there a way to open the bonnet?
What didn't work with the manual key, do you mean the lock wouldn't turn ?
It is quite stiff.
Try the spare key, the original may be flat, even if you could just open the boot you can then manually open the charging port flap & topping up the car may also help the 12 V battery if that's gone flat
Try the spare key, the original may be flat, even if you could just open the boot you can then manually open the charging port flap & topping up the car may also help the 12v battery if that's gone flat
I tried the spare as well but no response. I’ll try again when I’m home if not I guess a call to the AA tomorrow morning ?
I was pushing hard and it would turn but nothing would happen? I felt like if I would turn harder something would snap?
This is the process for opening a ZS EV by using the emergency blade, if your 12 volt battery is flat.
I assume it will be a very similar process on the MG4.
    Votes: 965 77.6%
    Votes: 185 14.9%
    Votes: 93 7.5%
