Charging Cables
Yes, get a three phase 32A Type2 cable for the MG4 - 5m is useful. I have a 3m and it's fine for most chargers but occasionally you need longer. So go for 5m if you can. Our original ZS EV from 3 years ago also didn't come with a Type2 cable (just the granny charger) so this is not new for MG. I also think it's a bit mean when you're paying circa 30K for a car, but there you go. Kia supplied a Type2 cable with my e-Niro, but only single phase, where the car can support 3ph (11kw) so "close but no cigar!"
Not that anyone will be bothered as I'm just being a bit random but my Megane came with 3 phase 22kw cable as standard
But does it have a self emptying gearbox, under car air scoop and anti hijacking locking system ?
It's a seller's market. Don't like what it comes with? Tuff, there's only 120 behind you who will be.
Sad, but until the market/chips/supply issues ease, that's the way the cookie crumbles.
Agree mate just took delivery of a brand new Discovery, took a year from order to pick up, he went to pick it up and said the salesman actually said to him "it's fine if you want to change your mind, I can sell it for more tomorrow"
£50k motor, my mate thought he was joking turned out he was being serious, seemingly a list of customers willing to pay more to avoid a years wait.
Lovely big motor but it's the size of a battleship
My 10 day 'old' pre reg MX-5, with 3 miles on it, sitting in the showroom, costing 6.5 thousand pounds less than a 'new' one seems long time ago :(
Would definitely cost you more in the same circumstances now I'd imagine
Charging cables appear to be a hot topic.
A word of caution about purchasing a 3 phase charging cable as it may not deliver the charge you expected from a single phase supply.
The following information was seen on:
Important Note About 11kW Cables: 11kW cables (3 Phase, 16A) are not usually ideal as a general
charging cable in the UK. This is due to the fact that most EVSE (Charge points) in the UK are single-
phase only. This would cause your 11kW cable to charge at 1 phase, 16A which is a 3.6kW charge rate,
the slowest you can get! Most users would benefit more from a 7.2kW charging cable or the heavier
22kW charging cable.
I’ve just ordered a Tesla cable rated 32A:
Type 2 Adapter - 32A
4 m
Quantity: 1
£85.00
Subtotal£85.00
Standard ShippingFree
Total£85.00
Including VAT £14.17
Shop FAQTesla | Privacy Policy
i had assumed that it was 3 phase But I’m not sure now.
Paul
4 m
Quantity: 1
£85.00
Subtotal£85.00
Total£85.00
Paul
Yes, you are good, the Tesla type 2 lead is a good option, its both 3 phase and 32 amp the 2 key elements for LR owners. Get 11kw on 3 phase and 7kW on 1 phase. Not sure why you would buy anything else, unless you need longer than 4m, or were really worried about the weight or stiffness of a 3phase lead.
SR owners may choose something else if they are worrying about a few ounces of weight or the flexibility of the lead. At £85 the price is difficult to match.
I see 2nd hand dubious cables selling for more than that on fleabay. I’ve also seen a Tesla cable advertised for £100!
Not sure how Tesla do it, I see the individual plugs go for £40.
Probably not about how Tesla do it, more how much others make from it ?
I'm sorry that most of our members appear to have missed the point.
Having a 3 phase cable is no doubt useful as it can still be used to charge from a single phase charger.
The article in - EV Charging Cables & Connectors For Electric Cars | EVCables.co.uk clearly shows that the cable will work in both three phase and single phase chargers but makes the point that there are few three phase chargers in the U.K. and when the cable is used on a single phase charger (most in the U.K.) are single phase, the charging rate will be at its lowest - 3.6kW.
It is better to have a single phase cable rated at 22kW, 5 or more metres long for the best all round usefulness.
Not sure your point, many of the post above are clear on this. The Tesla lead is 32 amp 3 phase 22kw, as it 32amp it will give 7kw on single phase. And it's cheaper than many 32amp single phase leads so little to lose. Other than 1m that is very rarely needed in my experience, you may have a different view with the charge port location.
Much as home charging will be single phase 7kW, out and about quite a few are 22kW and LR owners will get 11kW.
SR owners will only ever get 7kw as the onboard charger is limited.
The description about the 3 phase cable only giving 3.6kW on a single phase charger is referring to a 11kW 16A 3 phase cable. A 22kW 32A 3 phase cable will give 7kW on a single phase charger. They are making the point as they sell both types.
A a 22kW 32A 3 phase cable is definitely useful for LR/Trophy if you happen to have any suitable chargers around. I'm in Scotland at the moment and lots of the chargers where I am are 22kW.
Got to agree quite a lot of the Charge Place Scotland chargers are 22kw, definitely worth having a compatible cable.
My Megane will take the 22kw so it's a bit of a bonus having the charge place Scotland chargers, especially how reasonably priced they are
I have a test drive booked tomorrow, and I wanted to know in advance what cable is supplied with the car?
TIA
Our dealer asked me what cable I wanted. You can choose between either the Type 2 or 3 pin plug but not both.
Thanks, do you have a link to share please?
You need to download the Tesla App (App Link GPlay Store) and login/create an account.
Once you have and are on the main page scroll down to the bottom and Click on Tesla Shop.
Within there Click on the Stay Charged image
And then the Type 2 cable is under On the Road section if you scroll to the right.
See images attached for Shop, Stay Charged and On the Road screenshots.
If you do it on the website supposedly it checks if you're an actual Tesla Owner but on the app it doesn't as you can have the app without being a Tesla owner due to them opening up the network for charging non Teslas.
Hope this helps.
    Votes: 1,014 77.9%
    Votes: 191 14.7%
    Votes: 96 7.4%
