Charging in rain with granny charger. Any problems?
Scifly
carrickfergus
MG HS PHEV
Is it ok to charge in the rain? Does rain gettting in around the car plug end or onto the charging unit cause any problems? I am using IP66 external wall socket with built in RCD so no problems there. Mostly concerned with rainwater splashing in and around the car plug end.
MG HS PHEV Trophy 2 weeks old
Just make sure that the plug and socket are kept dry the charge is water proof, I have charged for over two year with no problems but did buy a cover for the car charging opening to keep rain snow and frost off.
Where did you get the protective cover from please?
It is designed to be charged in the rain.
Torrential rain.
Just don't jet wash the socket whilst charging (or discharging)
No covers required.
Only if it makes you feel better.
I've been charging from the granny charger for a full year and never had any problems. I have an industrial extension cable from my utility building/garage at the back of the house all the way (30m) to the hedge at the front of the house. There's a double garden/waterproof socket on the end that I plug into.
There's been a few stress fractures around the plastic socket but I'll just replace it in the same housing this summer.
Thanks for the image, i had the same idea to add a crosswalk protection but too bad this is strictly forbidden in the Netherlands. And the housing association don't allow charging EVs from your home as well.
Same no issues
