Charging indicator off
arkaplanda
turkey
I am charging my EV4 at home. I want to turn off the green charging indicator during the charge. Does someone know if there is any way to do it?
Doesn't it go off a few seconds after you close and lock the car door? What model do you have?
I have EV4, the green lights are always on during the charge. What should i do to turn them off?
I am not sure of a way to turn them off...
But charging for the first time the other day, only 3 were lit (top left not lit) - assumed that was the % full as we were about 60% so well into the 3rd 1/4
Is that not usual?
Is that not usual?
Each light is 25% so your 3 lights will mean you've got between 50% and 75% of charge.
Apart from removing the fuse no there isn't. If you just want to stop the lights from illuminating the surrounding area you could use something like this.
IIRC one of the interior fuses if pulled will turn off the charging lights. (F9 I think)
Having had a look at the wiring, I think the cable latch is on the same fuse as the door locks - F15.
    Votes: 1,052 77.9%
    Votes: 204 15.1%
