Charging problems
John mac
Ryton
My mg will not charge at home with the 3 pin plug even through its wired through a cooker socket which mg advise but it will charge from other people's socket I have pv panels on my roof and a battery pack installed I was wondering if that is affecting my home charging anybody else had this problem
Hi yes I've had an outdoor socket fitted through the cooker socket and this is live when I plug the 3 pin socket into it the charger connects to the car then stops charging after about a minute
The grany EVSE could be sensing an earth leakage and shutting down. Better get an EVSE electrical engineer out to check it is correctly fed and protected.
The grany EVSE could be sensing an earth leakage and shutting down. Better get an EVSE electrical engineer out to check it is correct fed and protected.
Yep, it looks like that big box with the lights on between the plugs is doing it's job. :)
Have you checked the car has not got scheduled charging set? Connecting then disconnecting a minute later sounds like what mine does when I plug it in, but I have set to charge overnight.
I don't have a Mark 2 with scheduled charging. Maybe the video in this post will get you close:
