Expat Ever
- Mar 2, 2023
- Location
- Chiang Mai, Thailand
- MG4 SE SR
Today I inadvertently ran the main battery down lower than usual and just now plugged it into our MG wall charger when I got home. The charger reliably provides 7.2Kw when topping up in my usual range of 25 - 75%, but with the battery at 10% it was only working at 2watts. The charging port 0-25% light came on blue for a few minutes and then went out. The display on the MG wall unit behaved normally showing its cycle of nine green flashes.
The charging rate is second from the bottom (my power used so far this month)
The driver's display reported the charging door open and "High voltage battery shut down" with a red symbol at the top right and a yellow one in the bottom left. Other than that, electrics in the car interior appeared to work normally. Clearly, at 2watts it wasn't going to charge so I have connected the Granny Brick instead and that looks like it's working normally, drawing 9.5A at 229V from a domestic socket.
Anyone had issues with using the supplied wall box with an almost empty battery? (mine is a Thai 230V 7Kw ingle phase version: see the picture attached).View attachment 20304
