- Apr 10, 2023
- West Linton, Scotland
- MG4 (2022-2025)
I think I'm over-complicating the issue. I'm looking at battery settings, but this isn't primarily a battery setting issue, it's an issue with the house. The fundamental problem is that the system prioritises the house to use solar rather than the battery. The house uses solar first, failing that battery, failing that grid. Even if the battery wasn't allowed to charge from the solar, the house would still use the solar first, and it's the house usage that's driving all this.
The house prioritising the solar is the cause of the battery remaining at 100% all day - it simply isn't being asked for the electricity it has stored. If it was being asked to supply the house, it wouldn't matter that it had an underlying instruction to charge from the solar if it could - it would never be able to do that, because the house demand is incessant.
The house should be instructed to take electricity in ascending order of its effective cost. The battery is always going to be the cheapest, because it's always charged at 7p/unit. The solar is next, with a notional cost of 15p. Grid is bottom, because at the time when solar is available, grid costs 23p. The house should only use grid when neither solar nor battery is available, which in practice will be 11.30 pm to 5.30 am, when the battery is set to charge.
So I think I have been asking the wrong question, or rather I have been asking two questions where one is enough. Because all the settings on the inverter relate to the battery, it's natural to try to find a battery setting that will fix this. However, it's not a matter of telling the battery not to charge from the solar. It's a mattery of telling the house to run from the battery in preference to the solar.
Yes, set up like this it does end up looking like two separate systems. One system that uses cheap off-peak electricity to power the house all day by storing it in the battery, and another system that generates electricity from solar and exports it as a cash-generating exercise. They could even be separate, except that if the day comes when the export tariff is below the off-peak tariff, you'd want to switch the priorities back agan. Or you might want to let the house use some solar if you had a day when you anticipated that the demand would be greater than the capacity of the battery. But as a default, at the moment, telling the house to ignore the solar really ought to be a default position that can be configured.
Unless anyone can tell me why this isn't possible?
