Rolfe
Moderator
- Apr 10, 2023
- West Linton, Scotland
- MG4 (2022-2025)
Well, here's the plan. The daytime settings worked perfectly. From 7 am to 5.30 pm the battery was set to export to 80% (that's arbitrary, it just has to be higher than the amount of charge I expect to pick up in that time. That directed all the solar (above the house load) to export, until clipping started, when the excess was directed to the house battery. Today that brought the battery up to 56%, which is plenty and to spare. When clipping ended the battery stopped charging and export of the solar continued, and the battery kept the charge it had gained. Didn't have to change anything, it all worked perfectly.
At 5.30 pm (when the solar can no longer meet the house load) the export setting ends and the battery then powers the house through till 11.30 pm. Anything left over can be exported for profit just before 11.30. So far so good.
However, what happened during the night, during the time when the battery would normally be charging, was a load of random fluctuations that weren't terribly helpful, and I still ended up importing a little peak-rate power. So now I think what I need to do is export down to say 12% or maybe 15% in the late evening, rather than exporting everything. Then if I keep that export limit throughout the night, that should preserve that amount of charge to run the house 5.30 am till sunrise.
If this works then it's close to being set and forget, any time there's a nice day. Nice days being so infrequent sometimes that I'd better write it all down so I don't forget.
