Confusion
OriginalBigAl
France SE,LR23
MG4 SE LR
To avoid confusion between this forums participants could everyone say which of the now 8 versions , 3, 2022 and 5, 2023 models you have or referring to when posting. The generality of MG4 in reality does now not exist. Cheers.
Is there a standard means of referencing them to distinguish?
This applies across the whole forum.
Making full use of your profile helps and it can be adapted to convey more detailed information as you can see in mine.
Would help if there were more options under the “Driving“ section of the profile but I guess they must be limited?
It's problematic because you end up with a very long menu list to cover all options. It can be done but it becomes messy.
On another forum I run, I solved this problem by making it a free text field so the owner could input whatever they liked albeit with a limited character count.
That might be better.
Put the exact details of your car in your sig line, guys.
The signature line doesn't show up if using a phone
I changed my username to indicate which model I have, as a test. Unfortunately they delivered the phase 1 so will have to change it again ?
    Votes: 943 77.6%
