Alb
Moderator
- May 11, 2021
- Solutions
- 3
- Location
- MG5 Mk1 SR
- MG5
I don't have gas.
Wow that’s a very good rate mine is 18.59p/kWh 24 hrs no reduced rate at night .I was very lucky in my timing when I went onto Octopus Go because I just made it onto the 2018 tariff so my daily rate is only 13.72p/kWh. They introduced the 2021 tariff just a few days later.
That's spot on. Hours x Kw x £/kw.Shoud be 12hr x 2.2 kw x 0.19 cost = £5.016
Yeh getting about 120 for £5 , I think diesel is about £6 a gallon and I was getting about 35/40 mpg so treble miles ain’t badThat's spot on. Hours x Kw x £/kw.
You can buy a power usage meter from Amazon or elsewhere for around £20 that will tell you more accurately what you've used.
Something to be aware of is that there is some amount of power lost in heat during charging from an AC socket. So in the above example, where you're estimating about 26.4kwh ( 12hr x 2.2kw ) usage, you may find that only low twenties ends up in the battery. It's an awful lot cheaper than petrol anyway ( for now ).
In Victoria, Australia, electric vehicles are taxed at three times the rate of petrol vehicles. A litre of petrol is rated at 9.1kwH. Electric vehicles use around (18.2 kwH) per 100 km (or better). The same car running on petrol and using 2 litres per hundred km would pay 2 x 42.7 cents in tax. I.e. 85.4 cents per hundred km. Instead, because the car uses electricity instead of petrol it is taxed at $2.50 per hundred km, almost three times the rate of the petrol car.Did you add 5% for VAT?
