Some of those outliers are way out there. 570km on a full charge???? Downhill all the way with a tail wind for the whole distance????
How did you achieve that?
Even the run into Melbourne isn't 570kms, even though it's all down hill .... heading into a hole is generally like that .... maybe he was going round the outskirts, slowly working his way in, like one of those charity coin wishing wells .....
T1 Terry
It's a normalised range estimate, not an actual achieved range. So if the driving at that time had very good economy then the normalised 100% SOC range would correspondingly go up.
If we have a period with nothing much other than slow driving on our local roads (with 40-80 km/h speed limits) we can see range go up quite a bit.
As you note there are some "outliers" - whereas the majority of samples occur within a fairly tight band of economy rates with some bias overlayed due to seasonal impacts and to some extent the type of driving.
You can see a cluster of dots about halfway along the chart with poor economy and low normalised range - that was when we moved home and I was doing a lot of towing.
And there are other small clumps of dots with a low normalised range estimate - these would correspond with longer highway trips away from home.
    Votes: 1,090 77.8%
    Votes: 209 14.9%
    Votes: 103 7.4%
