Electrifying on used MG5s!!
I thought the SR was quicker than the 8 seconds she said.
She also referred to the new version as the 'executive' model?
Is the long range much quicker than the SR? I have driven both, seemed the same to me.
Both quoted a 0-60mph in 7.3s, (or 0-62mph/100kmph as 7.7s) - admittedly the LR is every so slightly heavier (15kg to 18kg) but the manual says it has a peak torque of 280nm rather than 260Nm for the SR (can only imagine this is a feature of the different battery pack as motor meant to be the same).
So - I suspect they're as near identical performance as makes no difference.
Edit: They're still perpetuating this nonsense that the SR can only charge at 50kW whereas the LR introduced 80kW charging - which is untrue, both support the same rate.
