Granny charger cable supplied?
avdb
Scotland
Is there a 3 pin UK charging cable included with a new Cyberster?
Thanks
Yeah, mine came with a standard. It's a good size too. Every video I've seen on Youtube shows the same bag when looking inside the trunk, so I suspect it's included.
Didn’t get one with mine back in October. The bag in the boot is the Type 2 Charging cable for supermarket / slow charging.
I did not get one either - just the type 2 cable which is too short to connect to my charger.
There were no charging cables with mine when I picked it up last October. When I questioned the dealer about it, he seemed to think it strange that none were supplied with the car and subsequently disappeared returning a few minutes later with a type 2 cable he said I could have.
In Australia my Cyberster was delivered on October 29th, it came with the type 2 standard charging cable in a neat zip canvas bag with the MG logo. The length & the cable have not been tested because I have a 10.5 kW solar system with an installed 7.5kW single phase charger which is suffice. I did however order, paid A$250. and received from MG a car to load cable which came in a similar bag with the MG logo……..after market cables from Amazon are cheaper but you never know if you add a non OEM product if it might cause a problem with the 10year warranty in the future……just a warning ‼️
In South Africa we get the same but with an Aussie plug on the end so an adapter is needed. Also the sat nav has no maps and the nearest dealership shows as in Perth. Assuming a s/w update will bring a fix shortly
