Handfree closing tailgate
George MG HS PHEV2025
Warwickshire
HS PHEV
Had my MG hs phev trophy for nearly month, it is my first MG car and I am still learning how to get all features work. One issue I come across is how to handfree close the power tailgate:
The user manual said that the tailgate can opened or closed by kicking foot under the center of rear bumper. I managed to open it by doing so, but failed to close it by kicking again - it beep twice but no moving the tailgate.
Contacted MG UK Customer Care, I was given section of the user manual and directed me to local dealer. I wonder if anyone came across the same or similar issue, if so how it was sorted out - kick closing the tailgate successfully.
Thanks in advance for your kindly assistance.
George
How long was the boot lid open for, before you tried to close it (with the foot action)?
I think it "times out" after a while.
TBH I don't use the facility, mine is not that sensitive, and I spend too long kicking - looks like I'm attacking the car!
I know it works because I can always rely on the lid opening (inconveniently) when I clean that area of the car.
Not sure if it’s the same as the S5 model that we have, but I strongly expect that it is.
But our S5 is the same, you can use the “kick sensor” to open the hatch / tail gate, but if you try and repeat the kicking action to lower the hatch, it is not happy !.
It makes the same beep - beep sound and will not close.
You have to use either the button on the fob, or the push button fitted on the R/H side of the hatch trim panel.
I have my own theory here 🤷🏻.
The foot sensor switch will not obey a command to CLOSE the hatch for safety reasons to avoid a “trap” situation.
E.G. - You have opened the hatch to load items into the boot, you are reaching to the rear of the boot packing your items.
The front of your legs are up against the rear bumper, your feet 👣 are slightly under the car.
You move one of your feet 🦶 and you accidentally trigger the sensor, the hatch starts to close and you are still packing items into the rear of the boot.
Not a nice experience to have the hatch hit you in the head or back !.
It will reverse on contact of course, but not nice never the less 🥴.
This maybe be the reason it is this way then 🤷🏻.
Hi, BPM06, thanks for sharing your story. The tailgate opening was not long, e. g. loading shopping.
Hi, Lovemyev, for your sharing your story and thought on this issue.
It might be the case for safety reason as the tailgate opening height has been set about 80% full open to accommodate other members of family while made it not very far above my head when approaching to kick it close.
Hi, surely the using the kicking action to open the tailgate is to assist when you have your hands full. Once you have loaded the items into the boot then your hands are free to close the hatch with the button or remote, and the need to kick isn’t required.
My wife is five feet nothing so the push button on the tailgate is useless to her.
She uses the open button on the key fob to close the tailgate, you just need to push and hold it for around 5 seconds to activate it
My wife is just able to reach the button if the car is parked on the flat, but she is unable to reach it when the car is parked on our drive, as the car is on a small decline facing forward.
It can be closed it after you enter the car, by using the tailgate button on the info screen in the head unit, however I am not really sure about doing this while siting inside the car though ?.
I usually tend to use the button on the fob for opening and closing tbh.
This is the first car that we have ever owned with a powered hatch / tailgate and it is a great feature, I love it.
Hit the button on the fob as you approach the car at the super market and straight in with your heavy bags - brilliant !.
I have got caught a couple of times, when pressing the “lock” on the fob, before the hatch has finally latched.
This will sound the horn because it thinks the hatch is still open, more importantly you can walk away thinking it is locked, but of course it is not !.
This is verified because the door mirrors are still unfolded !.
George
Mine doesn't work so far? thought it didn't have the feature ? Had the car a week. Better go try again !
No, the kick sensor is for opening only.
Well you can kick under the bumper till the cows come home and it still won't close. It will still beep as if it is going to do but it won't. It may well be that it works on foreign versions but who knows, perhaps MG might.
As a matter of interest it closes using the "tailgate function" on the infotainment screen under "convenience" but other than that it's either the button on the tailgate or key fob.
I thought I'd read somewhere that after doing the kick motion you had to take a pace backwards before the hatch would close? In case your body is in the way. Probably far too clever though! Maybe I read that on another forum?
I noticed that opening and closing the tailgate using the infotainment system automatically adjusts the height to LOW, so please be careful if you use this system NOT TO OPEN THINKING ITS GOING TO OPEN TO FULL HEIGHT.
Not for me, it always opens the same way, regardless of whether I use the remote control, infotainment system or button.
Has anybody else noticed, that if you are commanding the hatch open or closed, from the head unit screen, it only works if the car is in N or P on the gear selector.
