Yes, for ACC that is the latest.
But in general, if on ACC and you overtake the vehicle in front of you within the set minimal distance, once in the left lane the car still drops speed. This is worse with OPD compared to other regen options. You can complain about that to force them to go into the software updates.
If you do a pull down on the right top side of the infotainment screen, a number of settings are offered. In the latest updates it brought the ELK button (yes, it isn't named LKA). If you use LKA (any mode), you can tick the icon to disable any LKA mode (Alarm, LDW or ELK). Since the manual urges you disable it in certain circumstances, tell them you need that button for safety reasons.
Next, make a complaint about losing BT connection, and poor AA/AC functionality.
This way, I expect they will at least install R67 and others. That also includes the improved temperature calibration (it was 5 degrees off).
And hopefully, that fixes it.
Btw, have you tried setting the temperature to 30 degrees to test A/C heating?
