HELP NOT CHARGE
P6cat
North Wales
My ZS mk1 will not charging
Says connected not charging and doesn’t change
I have tried another charger with no luck
Any ideas I need the car tomorrow
Hi
I’ve had it since new over 4years now
I’m using a 7kW charger which has been working fine and I’ve tried the granny charger but no luck
I’m now trying to charge the 12V battery and I also tried a reset by disconnecting the 12V battery for 10 minutes.
Hi
I’m using a 7kw charger which has been working fine and I’ve tried the granny charger but no luck
OK.
A Long shot then, try disconnecting the 12v battery for 10 minutes.
Reconnect and try again.
But try locking and unlocking first.
We posted at the same time there!
Good Idea with the 12V battery though.
Let's see how you get on.
If you have a voltage reader test the battery.
I'm off to bed.
Good Luck.
Yes I think this was the problem it started charging and I got a full charge
I have since changed it with no issues???
Thanks for your advice
