Going to install a home charger and requested some quotes.
Any recommendations for ease of use particularly with a 4 and support.
Any point in buying anything smarter than what the App and car offer?
We are with Octopus Go which gives us 9p pkw hour from midnight (12.30) to 4.30 in the morning. We are waiting to go onto Octopus Inelegance EV tariff as soon as we can, that gives cheaper electricity and for two more hours (Aug23 info). I see others are able to use Octopus intelligence which Octopus are not able to offer in our area (Hence Octopus Go at the moment!)
We purchased a MyEnergy / Zappi solution for £670 and had a electrician / friend install it. Note - This solution can use what is known as a CT clamp that can be (not required) clamped to your mains supply (Simply clip / clamp around the mains supply), that uses technology to review what's being used in the home to ensure the fuse does not blow / trip. For example, electric shower, kettle and cooker are on and are using "x" power, so EV (Zappi) will know how much power is being used in the home and reduce how much to send to the car to ensure the fuse does not trip / blow.
It's a nice bit of kit. We continue to play around with trying to schedule it to only come on at the times we are at the cheapest tariff. This is not very straight forward.
Zappi technology also interact with your electricity grid and solar panel solution (Optional and if applicable). You have a fast charge (Charge regardless), ECO and ECHO+, that can work with other solutions (or independently) such as a home installed solar solution.
Note with our MG4 EV - We have noticed (perhaps a software glitch) that when we set our EV to only accept a charge at a certain time, this function is not working with our MG4 EV. This may be a software problem we will review later. we are still playing around with My Energy / Zappies "only charge at these times" options. Zappie comes with a (5 meter attached to unit) cable and without (Without = use your own) EV cable. we purchased the one with cable (attached).
We remain happy to date with our Zappi / Myenergy solution.
I would say allocate anything between £800 to 1k for the kit and install. However, if CT Clamp Kit available (as described above), you may want to discuss this part of the install separately and or include it in the quote. If your garage is / kit far away, a cable needs to be run from the kit to your mains home power (Clamp to go over mains power, where the fuse box is, so that the kit can monitor what your home is currently using to decide how much power to give to your EV at that time).
