I have never used it, and it's something I'm really confused about. There was an earlier thread where people tried to explain it, or work their way through their misconceptions, but I never got it clear in my mind. (It was originally split off as a derail from a thread about cabin heating.)
Does the bug affect cabin pre-heat, battery pre-heat or both? I decided to do a battery pre-heat this morning. Started it 90 minutes before departure; app said it was on. Looked again 30 minutes before departure and app said it was off.
www.mgevs.com
When I first got the car the weather was still a bit chilly, but as things warmed up I was occasionally, like @AlunJ, getting random suggestions from the car about pre-heating the battery when the temperature outside was like 17ºC. After a bit I clicked on "don't tell me this again" and it never has, even when it's been below zero.
I know about pre-heating as you approach a DC charger, but how much of your remaining charge is it going to drain, and do you really get enough of a boost in charging speed for it to be worth it? And how long do you pre-heat for (LFP) and how cold out does it have to be before you should do it?
I also know about pre-heating before a long journey in winter, but again, how long for and how cold does it need to be before it's worth it, and how long does the journey need to be before it's worth it? In addition, since my car won't pre-heat when plugged in but not charging, I'm a bit hazy on how I'd even do that. I'd drain a fair bit out of the battery, which really doesn't seem worth it.
But then again I wonder, if I don't do this, am I likely to harm the battery? I honestly don't have a clue.
