How to unbind my MG4 from the Ohme Home Charger?
Loveclose
Andover UK
Literally picking up my new S5 tomorrow.
I'm getting bits ready for the change - I have found how to unbind the MG4 from the MGiSmart app, but am not seeing how to unbind it from my Ohme Home Pro app - I can see the 'Manage my EVs' ok, and I've added the S5 already, but can't see a way to remove the MG4.
Any Ohme folk out there with a solution??
Cheers!!
Cheers!!
Just create a generic car - mine is a 144kWh battery, with a 3.8kW charge rate, as like to charge as soon as I plug in with octopus.
Thank you, but I've already added the S5 to the list of cars - I just need to remove the MG4 from the list if possible.
The S5 data is on board within the app, and I can simply switch to the S5, but that would leave the MG4 in app, and I'd rather remove it if possible.
Cheers!
Cheers!
If you want to remove: settings> My EVs> MG4 > Remove EV
If you want to remove> settings> My EVs> MG4 > Remove EV
This is where it goes wrong for me,
I hit the settings wheel, bottom right corner.
Below my name and address, there is a My Charger icon, then Manage my EVs. Opening the MG4 icon gives me a few tech specs, but no option to remove EV.
Am I barking up the wrong menu?
I have 2 cars, a fast n slow charge - on my Ohme fast I can delete, but not on the other.... not sure how to help further - having said this, I select the correct car / profile at the top under charging
Update - I 'unbound' the MG4 today at the dealership from the MG iSmart app.
Strangely enough, the option to 'unbind' the MG4 within the Ohme App appeared afterwards, so I now only have the S5 available in the Ohme app as required.
Thank you to everyone who helped out!
    Votes: 1,023 77.7%
    Votes: 198 15.0%
    Votes: 96 7.3%
