ARvanHAS
- Jun 5, 2020
- Dordrecht, Netherlands
Hi all.
My car came with the updates installed, at least, that what they said when I picked it up.
I assumed that was right because the GON is permanetly shown on the cockpit screen and the outside temerature is on the screen of the mediasystem.
But I just found out I only got Comfortpack 2 installed, not the 2 other ones.
The good news is, it turns out you can update it yourself.
Because I couldn't find anything in the manual nor in any post about this how to do this I made this post.
The best way to do this is with a laptop in the car, but internet is required.
You can check if you have the latest updates yourself by putting a formatted (FAT32 or exFAT) USB stick in the USB port which is also used for Android auto. Then go to setup/System in the Mediasystem, then scroll down to Update Navigation and press [Start]. Wait a bit untill the system asks if you want to use the USB stick, press [Yes]. When it is finished is says something like "the USB stick contains information about the current software and you have to go to NaviExtras.com"
This is appears to be a MG website wich has software for our navigation system (free and payed updates)
First register by selecting your car (in the Netherlands that is MG ZS EV Western Europe (UK) - so not the non UK one) and fill in the rest ...
After that is done, download the available software tool for your computer (Windows or Apple), install it and start it. Plug in the USB stick and wait a bit. Login. The tool will recognize the information on the stick and tell you if there is any update available and if it's free or not.
Download the desired software, but only one at a time otherwise nothing will be installed in the car.
When the tool tells you to install it in the car, do so.
Go to setup/System in the Mediasystem, then scroll down to Update Navigation and press [Start]
After that and if there are any updates left, redo the whole routine:
format; go to car and put current software signature on USB, plug USB in computer and follow tool, update car etc.
Good Luck!
Or just call your dealer...
Good Luck!
