iSMART update
I thought it was a glitch when I saw the overheating warnings, so I thought I'd be clever and delete the app and re-install it. Now it won't let me in at all, it says I am not registered and it won't re-register. 😠
Why re-register? Just log in with your credentials.
Yes, that’s what I’ll do - just highlighting another issue with the app.
To be honest Stu - I don't bother "Faffing" with the slide control on the App.
I have mine set in the car to 80% SOC and if I have a long trip to make the following day, I just adjust the SOC % in the info screen in the car.
Better to find I have what need in the battery the following morning, other than to find the message did not get through to the car for some strange reasons.
Just a belt and braces thing really.
I’ve only had the car for a month and this is the first time I’ve had to change this so I’ll try to reset it to 80% in the app and see what happens. The app works well for setting the heating so we’ll see what happens after this charge.
I tried to log in and it says I'm not registered, despite having used it successfully for 5 months.
Sounds like you deleted the account instead of just uninstall app if you go to car is it now showing the QR code?
Great !.
I have tried dragging the percentage bar to 100% in the App, just to see if it's works to be honest Stu.
It does acknowledge the instruction I require, by quickly sending back a "Success" ✅ on the screen.
However, I have seen the same ✅ when I have requested the car to be either unlocked / HVAC preheat started and it has not worked on some odd occasions.
Not vitally important if the doors are not unlocked 10 seconds before I get there really.
this does not happen ALL of the time of course, because generally its pretty accurate.
I am just making the point, if you want the 100% SOC command to be a 100% guaranteed successful for your important trip in the morning, I would suggest that you set the 100% SOC command in the car, if that 100% SOC is an absolutely must have given requirement.
It may work completely without any hitch at all ?.
I trust the manual settings in the car, more than I do with the App is what i am saying.
Have safe journey with your new car !.
Hi Folks, I have the Gen 2 LR SE. The updated app iOS Version 1.0.8 seems to be OK. at least no error messages, imperial measurements etc. I do not have the option for alternate peripherals, but I do have an option for Digital key. does this mean my phone can unlock my car?
Yes and drive works well
I thought it was there before the update ?.
It was in android atleast
Maybe not ?.
Can’t see it ?.
I am still running on the previous version.
Hi all, someone earlier in the thread mentioned battery heating? from youtube I thought this was to heat up the batteries before rapid charging if the temp was below 10 degrees. Now on the app it states use 1 hour before use of the car? is this different?
