siteguru
Distinguished Member
- Sep 3, 2022
- Solutions
- 2
- Location
- Strathaven
- MG4 SE SR
When LKA is off in mine then it's off. No wheel twitching at all (unless TJA has been activated).
Mine is 50/50. Sometimes on and off.On my car it defaults to on. Though maybe that doesn't happen in the new software version? Oddly, it doesn't default to on quite as readily as the LKA does - sometimes if I've been out of the car but not shut everything down, only LKA needs to be re-disabled. But on every new startup, both have defaulted to on.
Maybe that's another SE software bug. If the speed limit recognition isn't needed for the NCAP rating there's no reason it can't remember its last setting.
I wouldn't mind it if it didn't lie to me so often, and if it didn't flash when it thinks I'm going too fast. It can be handy to have an accurate display of the current speed limit, but only if it's accurate, and if it doesn't leap about and make a distracting nuisance of itself. The display in Android Auto behaves well.
The biggest issue is the aggressive way it corrects, or follows something else it thinks is a white line. The video says that MG uk have invited MG China to experience how bad it is. Its configured for better roads as they are in China apparently. I was in a Ora funky cat Wednesday and that's as aggressive two with added brake applications. I watched this guy drive and the steering wheel pulled violently back into lane. I was chauffeured to Europcar to pick a loan vehicle up while mine goes in for whatever.... I asked about what mg4 was like to drive, and out of 4 staff members, no one can stand driving them. Manageress says they drive horribly and the problems I describe are pretty much standard. Maybe to yourself, you're physically well and the steering correction doesn't bother you, buy with me, it does.I don't understand this. In my car when I turn it off it is off. No ifs, no buts. I never experience it at all. If that LKA symbol is showing yellow, there is nothing there. Nothing.
You don't have TJA on, do you?
Reassuring that HKA (Hair Keep Assist) appears to be OK typical hairdresser my wife would have been proud .Stoneacre Derby rang today to just make sure alls OK to collect Monday. I've let them know in very good detail what is happening and basically begged them to disable all lane assist, lane keep software. The drawing is the best explanation I can give. A is the most painful for me. My tremor pulses the pains in my triceps, and then shoulders and neck start hurting. No other car has ever done this. I've been all over in this Tiguan and it's fine. So what is mg doing wrong?
