diabolikox
- Dec 24, 2024
- Teverola (CE)
- MG4 (2022-2025)
happy new year to all, a curiosity, but with R63 the weather doesn't work?
Seems intermittent. Originally did but for me sometimes says Implementation is failed.happy new year to all, a curiosity, but with R63 the weather doesn't work?
I had this problem, try this: Earlier posthappy new year to all, a curiosity, but with R63 the weather doesn't work?
it's the same on R59. After the servers were repaired yesterday i reactivatd my device and got a weather forecast. but just half an hour after it stopped working ("implementation is failed").happy new year to all, a curiosity, but with R63 the weather doesn't work?
Yea, I did this before the AWS issue, but then am now cautious about wiping my activations due to that haha.I had this problem, try this: Earlier post![]()
Yes, for now, I wouldn’t touch anything!it's the same on R59. After the servers were repaired yesterday i reactivatd my device and got a weather forecast. but just half an hour after it stopped working ("implementation is failed").
The servers seem to be pretty unstable.
i can't recommend reseting the activation, because if reactivating doesn't work, you are stuck with pretty much no functionality.
Having tested both R38 and R63 on my SE, I can confirm that the temperature offset issue seems to have been corrected in both releases.Do you mean from R59?
If R63 in the Trophy is anything like R38 in the SE then it should be accompanied by an HVAC software update. These updates make the HVAC target temperature work correctly.
Dived-in and ordered one for myself. Supplier is in Hong Kong and order summary was still showing 10-35 days (without paying extra) although did also note something like 5-10 days further down the page - will have to wait and see how it pans out...VNCI VDI3 Roewe MG Wuling Maxus Automotive Diagnostic Tool
www.obdii.shop
Came in a few days
It is definitely a separate update somewhere.... because I have R59 but my temperature worked correctly before I got that, due to some other update they threw at my car to try to fix various issues.Do you mean from R59?
I was really replying to @siteguru, not invalidating anything you said.Yes but the discussion crosses between Trophy/SE software and my response remains applicable irrespective
I put this down to temperature equalisation: once it reaches the target it gets colder to maintain. Is this not the case in your car?Is it really a temperature difference? to me it feels that after 20/30 minutes in the car, the hvac starts to blow significantly colder then it did at the beginning of the ride...
But this behaviour was the same on R46, 59 and 63, so it's not (only) a FICM issue
