MG4 Software Update Thread
The built-in maps on the MG4 are actually rather good (they’re based on Here maps), but the traffic data isn’t great.
I'm sure many on here have noticed that I don't have that many complementary views of the MG4, however based on my experience of driving all over the place (England & Wales) I actually find the traffic data very good, and pretty reliable. I use the Sat Nav all the time (even though I know where i'm going) purely for the traffic data.
I agree! Most people use AA or CP rather than the integrated navigation. The built-in maps on the MG4 are actually rather good (they’re based on Here maps), but the traffic data isn’t great.
The real selling point would be to have an integrated planner that could display the expected arrival SoC and reroute you to charging stations along the way.
The best option for that still seems to be ABRP. But then again, it’s not exactly straightforward: you have to check that the dongle is connected, reconnect it when it fails, and although ABRP is very accurate, it’s rather complex to use.
Wifey used the MG4 last summer to visit her family in her native Netherlands. She started with ABRP (using an OBD dongle) on the first day, but found the setup a bit too cumbersome and ended up just checking briefly whether the car could make the trip before simply using Google Maps.
You can use ABRP without a dongle. If you have homeassistant (or any other linux based server) you can install saic-mqtt-bridge and feed your car data directly to ABRP via it's developer id. Much more reliable and convinient than a dongle.
And to top it all off, you can map ABRP to one of the steering buttons and you have a seamless experience (for the most part).
And honestly, apart from tesla, ABRP is pretty much the best and most accurate routing app. If you give it the right data and train it enough, it becomes really accurate. Certanly much better than what most OEMs build into their cars.
It’s possible, but not exactly straightforward. Not everyone has a server at home, and developer IDs aren’t always available.
Tesla is on another level (I also own a RWD Model 3), and ABRP is arguably the second best choice. But using it to its full potential demands more involvement than most people are willing to put in.
Can you share please info how to do it. I have linux (ubuntu) server and want to try...
everything is explained in this thread
Has anyone got the built-in route charging assistance that @Odin reported they received with their R59 upgrade. And this was added to by @Mouss. See below
Also see pages 12 and 13 in the MG4 Trophy map update - beware.
The planner is not a feature integrated within the navigation. It is a standalone app. So you have to open the planner, select your trip, and then, the route is sent to the navigation app with the charging stops as waypoints. From this moment on, it’s purely static. It will not select other chargers based on your actual consumption or whatever.
Can we do the update from R63 to R69 with the USB stick without updating anything else? or is that asking for trouble
Is it safe to go from R63 to R69 using the usb without updating anything else or will that cause problems?
My dealer has just updated the MCU from 68.4.3.0 to 68.4.9.0 to fix the charger bar issue but didn't update from R63. Will carrying out a USB update to R67 cause any issues?
If the latest MCU update is installed, the update to R63 or better R67 should be possible without any problems
If i remember right the last step after MPU update to R67 is kind of "calibration files", i doubt that it can be done without SAIC software.
If you do R67 update from USB only, please post how successful it was, thanks.
    Votes: 1,047 77.8%
    Votes: 203 15.1%
