Mg4 Trophy SatNav
You can set your route preferences to avoid toll roads.
On the map screen tap the 3 dots on the right
Tap the cog icon
Tap More settings
Tap Navigation preferences
Then you can select what to Avoid on route
Tap the cog icon
Tap More settings
The problem lies not with wanting to avoid toll roads per se but wanting to take a specific route. In particular, I plotted a route using ABRP which took me via a specific chargepoint, and then on via a route that seemed interesting. Unfortunately it seems the MG satnav obviously doesn't find that route as attractive!
Does the MG4 Trophy have live traffic?
Yes, as I discovered when I ignored it's instruction to turn off the main road into a side road only to then encounter the mother of all traffic jams on the main road caused by an accident! In my defence, I've had a couple of occasions when the sat nav seems to have worked on an 'I'll get you close' basis and taken me to the wrong destination, so I don't fully trust it. In this instance, I should have taken note...
So this begs the question, could the 5 Trophy nav software (no live traffic) be updated using the 4 Trophy version?
As far as I know the car has a sim installed as you can set the car up to passenger as a hotspot givin 4G connectivity.
I am surprised then if the sat nav does not support live traffic, seems on odd thing to have such differences between the 2 cars .
The Trophy Satnav has live updates, switchable as required, but not always correct. On my recent journey it indicated a no entry to the M1 Southbound from the roundabout but in fact the closure was between the Southbound entry and the Northbound exits on the roundabout. I ignored its redirection.
Hello I'm new here, I've had my MG4 Trophy long range since 13-6-23, after having driven a Hyundai Kona 64kwh premium for two and a half years. I have sent a destination from the app, but I don't know where it is on the car. I find myself comparing it to the Kona a lot. On it when the screen comes on it asks you 'do you want to set this as a destination?' Simple.
    Votes: 1,052 77.9%
    Votes: 204 15.1%
