Solar or wind energy- the Eco is followed by 2 leaves as symbols not the ++ I have shown
Hi so lm glad you got that bit cleared up about + and leaves, the Zappi can charge in 3 modes, fast mode at 7.2kw and show FAST in the display, then you have eco mode Eco and one single leaf shown on the display, next is Eco Plus mode and on the display is Eco and 2 leafs.
Now in fast mode the zappi will use 7.2KWs and for example if your Solar is generating 2kw the zappi will use these plus 5.2kw from the grid, this grid draw will vary depending on what the solar is producing at any moment in time, but it will always output 7.2kw in the fast mode so at night time it will take all the 7.2 kw from the grid as there will be no solar.
Now in Eco one leaf, the Zappi needs 1.4 KW minimum and will get this from solar or grid supply, so if your solar panels are generating more than 1.4 no power is used from the grid and all of the output from the solar gos into the car, but if a cloud comes by and you solar panels output drops to say 0.8 kw the zappi will keep charging by drawing 0.6 kw from the grid to give you 1.4kw going into the car until the clouds clear also in this mode if your solar panels are generating more than 1.4 lets say 3.2 kw then the zappi will put the 3.2kw into the car assuming nothing is being use elsewhere in the home and if everything is being use in the home Zappi will just take 1.4kw from the grid to keep going until the home stops using power
Now Eco and 2 leafs this is know as Eco Plus in this mode the Zappi will only charge the car when your solar is generating more than 1.4kw and will never draw power from the grid so if your solar is generating 3.2 kw the car gets 3.2 again assuming nothing is being used in the home going to it, but if the solar generation drops below 1.4kw the charge to the car stops.
Also in this mode if let’s say the solar is generating 3.2 kw and someone turns on the kettle in the house which can draw 3kw the car will stop charging as the house will be taking all of the solar generation until the kettle turns off.
I for one never use the Eco Plus mode 2 leafs, as when the Zappi stops send power to the car because the clouds have come over or someone is using it in the house for the kettle or the tumble dryer the solenoids in the car are tripping in and out every time the power is lost from the Zappi and that cannot be good for them in my opinion as they can go on and off many many time in a day.
Anyhow RogerWill that’s my take on it just one other thing in the fast mode 7.2kw this will reduce down to around 0.3kw as the article becomes fully charge and can continue at that rate for a few hours sometimes as it does the battery balancing and then the Zappi will shutdown
In Eco mode one leaf, it will do this as well.
But in Eco Plus mode 2 leafs it will not as if the power drops the Zappi will stop.
Hope this lot helps.
Les
