MG5 rear wiper plastic clip / shroud (over bolt)
Bogrole
Bridgend, South Wales, UK
Just had a look around the car after washing it and found the plastic shroud that goes over the nut (or bolt) that holds the wiper in place is missing. Anyone know where I can get a replacement online?
Guessing it came off in a car wash at some point.
TIA
TIA
Cap rear window wiper arm New MG ZS - Brown and Gammons £3.30 IF THAT HELPS
I have the MG5. doubt its the same, but thank you
A quick search discovers it is the same MG5 and ZS
TIA
My MG5 was delivered with the shroud missing, but the dealership fitted a new one whilst I waited. I've knocked it loose a couple of times when washing the rear screen or lifting the wiper arm to clean the blade. It seems to be a relatively loose fit. I assume an MG dealership could source one for you.
TIA
After my plastic cover has come loose several times I've finally lost it. I've ordered a new one from my local MG dealer at £1.71 plus VAT. Might consider a touch of glue to keep it in place.
