MGS5 12V battery dead
I think you are missing something.
To effectively smart charge ev energy needs to know five data points.
1, Current charge = 40%
2, Target charge = 80%
3, Ready time = 7am
4, Battery Capacity = 64kw (also via API)
5, Charger Charger rate = 7kw
1 & 2 are only available via the API. 3 to 5 are inputed in the Ev Energy App.
With all five data points EV Energy now knows it needs to give the car 25.6kw of energy before 7am and it works out the best way to do that based on their algorithm and type of charger being used.. 25.6kw / 7kw = around 3 1/2 hours charge time (fag packet as there is a little more to it all). So it will work out how best to do this depending on your tariff and grid demands before 7am. It will stop and start charging during this time. Nothing to do with the car. All driven by EV Energy. See my screenshots. At some point towards the end the car will say I am at 80% and will stop taking charge but that is the very final stage.
Without these five data points the smart charging only gets less smart. And if its not smart enough it could cost you money. It will still "work" but its not working to the best of its capability.
How else would it know when to effectively start charging ? It has to fall back on what info is only in the app which isn't much help. e.g. Battery Capacity = 64kw instead of 25.6kw it actually needs.
If I am missing something then please say so.
What you say above makes sense, with the five points. However, if the Ev app is set to smart charge AND the MG app is set to smart charge, a charge is only delivered at the times specified in the apps.
I only required a small charge yesterday evening (to see if everything worked) , and as you can see from my screenshot's the charge was only started at 12am (start of my cheap tariff) and finished by about 2am.
With all the hassle I have had with my 12v battery getting drained, I am obviously very hesitant to give access to my mg account, even as a secondary account, in case my battery problems return.
Agree 100%!
In addition, I previously posted that my car was plugged in at 10:40 this morning and had almost immediately started charging, which gave some credence to the point made by @dx4100 that the ev.energy app does not control when charging takes place, although it is set to Smart Charge and use predominantly cheap electricity (in my case, between 00:00 and 05:00). BUT, that first charge lasted just over 1 hour (using a mixture of solar and peak from the grid) and then stopped.
The ev.energy app is still "in control" (and I have seen it behave like this before) and will complete the charge to 100% in that overnight slot.
So no, I don't believe the ev.energy app needs to have any direct communication with the car via the MG iSmart app; the car itself communicates with the charger and that, in turn, feeds data to the ev.energy app.
That isn't "smart charging"... That is schedule charging.... its also limiting your maximum possible charge to around 49kw (give or take). Which isn't a big problem most the time but it is a limit.
I know its under the smart charge features but your basically just pre setting a schedule. Thats not what most people recognise as "smart charging".
If it works for you then good stuff but I think we are looking at this from different positions. If you look at things like Octopus Intelligent Go - thats true smart charging and I regret not buying a charger compatible with it but the Ev Energy stuff isn't too far away. Schedule charging like this though isn't really smart charging.
Agree 100%!
I didn't say the ev energy app does not control when charging takes place. I said the opposite. If you are smart charging and you are not doing things like the previous poster has done and basically enforcing a schedule then the ev energy system will decide when to start and stop charging.
If you plugged in your car this morning can I ask what was the "ready by" time set too ? I presuming the next morning as thats the norm. If this is the case then what happened is what I would expect. The ev energy app has all day and night to decide when to best charge your car and thats what happened.
The information communicated between the car and the charger is fairly low level stuff like how much current can be drawn etc. It doesn't send detailed information like the state of charge etc.
Think about it. Why would they go to effort of API integrations if it wasn't required or provided benefit ?
I think we may have to agree to disagree!
Yeah fair enough - I got the impression that might have to be the case earlier today. I am posting more for the benefit of others at this point who may read this later on :)
Just more evidence on how it actually works. I need 10% tonight which is just under two hours charging. Plugged in and ev energy has scheduled exactly two hours charging. It can only do this if it had all the relevant data points.
Hopefully this helps people understand how it works.
Funny you would have two with the same problem. Mine has been great, and I've got a dashcam that goes into parking mode for 6 hours after I turn it off.
Not sure what's wrong with mine I had a dashcam fitted by Halfords because Thurlow nunn don't fit them and they said it was that that was running down the battery and re charged it and now it is flat again totally dead. The AA came out the first time and said the battery was faulty? But it was just re charged. Halfords have asked me to take it back and they will check it over but its dead and I'm not going back to Thurlow nunn
When you were in the car fitting the screen protector did you press the brake pedal to turn the car on?
If not then while you were sorting the tailgate out and fitting the screen protector the car's auxiliary systems would be powered from the 12V battery which wouldn't be being topped up by the main traction battery.
I'm not saying that you haven't got a defective 12V battery or that the one fitted isn't up to the job but that could be the reason. It might be worth investing in a jump starter power pack. It doesn't have to be that powerful as all it has to do is provide enough power to get the main battery relays to operate.
Which power do you recommend for jump starter power pack?
You only require a small capacity booster for a EV tbh.
But if you have a second car or friends & family members, that have ICE powered cars, you may consider it a good idea to chose a booster that can help others 👍.
Has anyone else had a problem with the 12V battery becoming drained overnight? I returned my first MGS5 due to this problem and today I have had exactly the same problem with my replacement MGS5, arghhhhh.
You are not alone! Picked up our new MGS5 EV on the 22nd Dec 2025. First failure was on the 2nd January. Went to the garage no fault found. It failed again 10 days later. It has been in the garage since, apparently MG have suggested some tests. The AGM battery was showing 3.2vdc both times. Car is back in the garage now since the 12th Jan. The replacement MGS5 EV demo car we are using has not shown the same issue to date.
Based on
Based on my experience with Marvel R, 5 times for a total of 17 weeks at the dealer garage in 30 months...., and users experience with other brand than MG, this seems to be a "normal anomaly" with many EV. With the Marvel R I got a lot of explanations but no real correction as I experienced a new problem 2 weeks ago. Thanks to the guy with a jump starter booster. I hope my next S5 will be free of these issues.
