Miles/kWh
It would be interesting to compare the energy use between a stardard EV and an EV with a 2 sp ratio available, allowing for a higher motor speed to wheel speed when max torque is required, then direct drive when low torque to rpm ratios are required ........
T1 Terry
So, not actually a practical suggestion for the vast majority of people going on trips outside of town.
For sure, it's true that you will get much better energy utilisation at 85kph vs the speed limit of 100 or 110kph. One of the best things to do if you are in danger of not making it to the next recharging station is to SLOW DOWN.
But... that's a very impractical methodology to PLAN on going slower than the speed limit and peeing off the rest of the vehicles driving it, particularly the single lane highways where commercial vehicles are using it along with the rest of us.
It takes a deal of effort for a B-Double to overtake someone pottering along well under the speed limit and causes everyone else stuck behind them to get cranky and think about performing dangerous overtaking manoeuvres.
While you may be maximising your energy efficiency you're not being the most thoughtful person to the rest of the road users.
Anyway, that's my take on it and I apologise if you feel I'm being rude, but I think it needs to be said.
I do plan on the trip at this speed, but have done it at the speed limit too. The difference of arrival time is about 15 to 20 min. Not much when not in a hurry.
The route I take is just about all dual lane, so not really affecting anyone else. Locally to reach the highway there is some single lane roads, but most of it has an 80kph speed limit. At the other end all the roads there are 60kph or 50kph. I do keep to the left lane at those speeds, unlike the Queensland convention of going slow in the right lane (Probably a side effect of eating too many straight bananas)
I am not trying to inconvenience anyone else.
These are definitely sensible things to address, that being said, "auto boxes" don't apply to our EVs. They have a single gearing ratio to ensure the car can achieve it's performance design acceleration and top speed. There is no additional "drive train loss" associated with it's use over the alternative, given that there
I am well aware that EV's are NOT Auto's and that is why I bought one. When my last ICE car was written off I could not buy a replacement without it being Auto. The dealer list EV's as "Auto" which is incorrect. They do use the same letters as Auto's, which is why I refer to them as pseudo Auto's.
is no alternative :LOL:
It's not as though there's a choice between a "Manual" EV and an "Auto" EV.
Pumping up your tyres is a really good thing to do. You should check tyre pressure regularly in any event.
Agreed. I run the tyres at about 39psi
I don't get it.
The torque the electric motor supplies is essentially constant irrespective of speed.
All I can see is you are adding additional mass for no gain.
When an electric motor is in the high torque curve, the energy use is the greatest, when spinning at high rpm it produces drive energy but less battery energy to produce it .....
yeah, that didn't even make sense to me when I reread it, I'll blame toasting the good health of Jack Daniels as New Yrs approaches over this side of the globe
T1 Terry
T1 Terry
Happy new year Mr Daniel’s and all his devotees. 🤩
I'll try this way of explaining it. When converting an ICE powered car to an EV using a 3phase motor, driving in a lower gear, such as 2nd, uses far less current (amps) than driving in 3rd or forth gear ......
It is an advantage to run a 4:1 diff compared to a 2:1 diff when doing an EV conversion
T1 Terry
Motor theory is slowly coming back to me, something to do with back EMF?
That's why stalling a motor will burn it out, draws a huge amount of current.
Faster it spins the more back EMF and the less current drawn, but higher revs means higher power.
Does that make sense?
Uncle Jack says this is not a good time to be asking me .... possibly the braincells that remembered that stuff are laying in a comatose state in the base of my skull ..... but bits of sound familiar, something about the faster the rotation, the shorter time for coil saturation, yet the inertia of momentum ..... yeah nah, that one just passed out as well :ROFLMAO:
Happy New Yr
T1 Terry
Happy New Yr
T1 Terry
Don’t worry about it - look how long they’ve taken to “perfect” ice vehicles 😂
This is how I remember it.
A coil spinning in between magnets, gets an induced voltage, ---- bring in alternators.
An electric motor is the same, but it so happens the induced voltage (back EMF), is in opposition to the applied voltage, so current is reduced.
Hello all from a cool Charente-Maritime in SW France. Here we are having our coldest winter for 20 years and my MG4 is suffering. She normal power consumption is 15.5 kWh / 100 km → ≈ 4.0 miles per kWh which is good and where we can realistically drive for 300km on a single charge. However, with temperatures hovering around 0°C all day and lower at night, I am getting 29.8 kWh / 100 km → ≈ 2.1 miles per kWh. In other words, power consumption has doubled, meaning that, for longer journeys I need to plan for more charging stops. A bit pricey to travel in these temperatures !!
Happy New Year. In Yorkshire the weather is the same and my Trophy's range is suffering too. But I believe the battery is also affected by my driving only a few miles a day so the battery is not warming through use. If I drove further I'm sure my miles/kWh would improve.
Are you only doing short journeys?
Now I'm going to have to give it a try, I'll give it a few weeks and see how I go.
Gave ACC a try yesterday on the way back from the airport, not sure if it's my old software, but I didn't like it at all. It doesn't look far enough ahead and gradually slow down, waits til the last minute and slams the brakes on. I have to acknowledge that it's going to save me from a speeding ticket, it holds speed better than I do.
When I hopefully get the latest software in a few months time it will be interesting to see if there's any improvements
Err... True if your battery and controller can keep supplying more voltage and power.
The motor torque is proportional to the motor current. The back EMF voltage that has to be overcome is proportional to motor speed. So if you keep the torque constant, then the current is constant, and the vehicle will accelerate. You need more and more voltage to overcome the higher and higher back EMF. So the power required (voltage times current) increases steadily.
What usually happens in modern EVs is that the maximum torque stays constant up to a certain very modest speed, say 60 km/h. This is the constant torque region.
At this speed, the controller is already supplying all the voltage it can. So the controller does some tricks with the AC phase to buck the motor's magnets, thereby weakening the effective magnetic field. This is the start of the "field weakening" region. The weaker field reduces the back EMF, at the cost of lower torque. As the vehicle speeds up, more field weakening is applied. So in this region, the higher speed and lower torque come close to cancelling out, so you end up with roughly constant power. So the field weakening region is sometimes called the constant power region.
This exchange of speed at the cost of torque is exactly what a mechanical gearbox achieves, without the hassles of a gearbox. Only very high performance EVs need a mult-speed gearbox (all EVs need the fixed reduction in the final drive), and usually the performance EV's gearbox is just two speed, and needed only for Autobahn or track speeds.
The above assumes a permanent magnet motor, but much the same applies to vehicles with induction motors, such as Teslas.
If your “intelligent” battery heating is on, consumption will be higher at the start of every journey. If you do short journeys heating the battery isn’t worth it, you’ll spend more energy heating it than you lose by not heating it.
So I have now turned OFF the (so called) "intelligent battery" and I have improved from 29.8kWh / 100km to 19.8kWh / 100km. To put that into perspective: in the warmer months, if I am on a highway at 110kph I will consumer around 10.5- 20.5 kWh / 100km. Today it is -6°C outside; I turned off the intelligent battery, had the internal heating and screen heaters ON and I yes, I was driving slowly and carefully on local roads but it improved dramatically.
So I guess the lesson is, keep it off until you know that you will be recharging later and only then, turn it on.
    Votes: 1,090 77.8%
    Votes: 209 14.9%
    Votes: 103 7.4%
