Coulomb
Moderator
- Apr 24, 2021
- Solutions
- 1
- Brisbane, Australia (ZS EV Mk1, MG4 ER 77kWh)
- MG4 (2022-2025)
I can't think of a use case for one of those. Maybe the manufacturers can't either, so that's why they aren't common?trying to find a grid tied inverter that takes a 12v input,
Did you perhaps mean a non-interactive inverter, so that you can run a coffee machine from your car? The trouble with 12 V is that even to get one lousy kilo watt at the output, that's 83 A ignoring efficiency, and up towards 100 A when you take efficiency into consideration. The DC-DC converter in a car typically tops out at 80-100 A; ICE alternators at ~50 A unless they are aftermarket.
12 V inverters also have the lowest efficiency, because voltage drops from saturating transistors and the voltage drop due to current flow increases with current. That's why most grid feed inverters are nominally 48 V, with a handful of smaller ones at 24 V and larger ones at 96+ V. So if you have the idea of using spare electric car energy to export energy to the grid at times of high feed in tariff, you'll only be "drip feeding" from 12 V.
