eric cire
- Sep 28, 2022
- Lincolnshire
- MG4 (2022-2025)
1 = only V2L on the car1 - are you just using the V2L of the car to do it rather than the V2G that Octopus has tested recently? If so, how are you connecting that much stuff to the car?
2 - How are you powering the car? I get using it as a battery by charging for cheap overnight and then powering the home, but that looks like you haven't charged the car unless it was done before the 12th and not used for anything else since
What’s the max V2L load that the car will take?
I paid £240.00 for this :Well done - I have a similar plan for December / Jan (as a back-up) each year mainly, as a top-up for my ESS (I have all the bits, just not tried it as a fully working system todate), and certainly dont want to take that much out of the car - what are you powering from the car? (I have a VE Multiplus II GX & Pylontech batteries - but only have 1 AC-IN, so am thinking of a dual supply transfer switch - can you confirm that you need a 1w 470ohm resistor accross CP & PP on the type 2 plug to enable V2L)
