disgruntled geordie
Just washed my new mg4 when removing some bird droppings it’s brought the paint off told it’s not covered in the warranty.any body else had this problem
Yes, but not to the paint, but to the outer surround to the door rubber trim - no major issue as its just cosmetic, these modern pressure washers can be very powerful on its max "focussed" settingJust washed my new mg4 when removing some bird droppings it’s brought the paint off told it’s not covered in the warranty.any body else had this problem
Has someone near you been breading pterodactylsYes, but not to the paint, but to the outer surround to the door rubber trim - no major issue as its just cosmetic, these modern pressure washers can be very powerful on its max "focussed" setting
EDIT: Pearl black also: but the paint survived - same issue:
I take it you recommend these wipes then? Was thinking of grabbing a box.Yup, had it on my wifes Volvo XC60. Bird droppings can be extremely damaging to your clear coat/paint, I feel your pain. It wont be covered by warranty as you now know. I keep a pack of these Autoglym Bird Dropping Wipes in my cars now, get rid of it as soon as you notice.
I haven’t tried these yet but I picked up a box from Halfords.I take it you recommend these wipes then? Was thinking of grabbing a box.
Ok. Definitely going to get some. I go out of my way to avoid trees but these will be a life (paint) saver when needed.I haven’t tried these yet but I picked up a box from Halfords.
This stuff and a microfibre cloth is great. Spray on, leave for a bit to do it’s magic, then gently wipe off…sortedI got some Poorboys Remover for mine.
Amazon product ASIN B0105BE6LC
I find them great ?I take it you recommend these wipes then? Was thinking of grabbing a box.
I use bits of paper towel on hardened bits to stop it running down on vertical surfaces.This stuff and a microfibre cloth is great. Spray on, leave for a bit to do it’s magic, then gently wipe off…sorted
I think those wipes are a bit expensive at £7.99 for 10 wipes thats 79.9p per wipe.
That’s true !.I find them excellent and good value. Could spend £8 on two coffees.
Not at Wetherspoons, £1.45 and free refills.I find them excellent and good value. Could spend £8 on two coffees.
The refills are free because it’s tastes like ……. Well - Not great and let’s leave it right there ?.Not at Wetherspoons, £1.45 and free refills.![]()
But free is free in Yorkshire.The refills are free because it’s tastes like ……. Well - Not great and let’s leave it right there ?.
?But free is free in Yorkshire.
