I’m still on the timed charging trail! Podpoint don’t seem to be coming up with anything anytime soon - so i thought - can a wifi timer be fitted to the supply to the charger? - and I found this on Amazon;
eMylo WiFi Circuit Breaker 3P 63A Intelligent Miniature Breaker Switch Automatic Reclosing Overload Protection Tuya Smart Remote Control Switch with Timing and Delay Function,Work with Alexa 380-400V : Amazon.co.uk: DIY & Tools
www.amazon.co.uk
has anyone done similar? Will it work? See any issues?
You are switching the full high load of course with this type of breaker.
Not that this can not be done, but I would check with a sparky on suitability on this type of breaker before ordering.
An alternative method, is to have control / switching of the control module inside of the wall box, via the low voltage signal wire to the car.
This can be done by installing a Wi - Fi switching relay inside your wall box.
They are cheap to buy online and small in size.
There is a couple that will do the job, I am using a “Sonoff” unit in my wall box.
This relay is controlled by a free “App” that is downloaded to your phone.
I have a four year old dumb 32 Amp Rolec unit installed and I have been using this type of arrangement to charge my car ZS EV for almost 12 months now.
I am on a EDF EV friendly tariff that gives us a much cheaper off peak rate at 7p / kw from 9.00pm to 7.00am every week day and the same cheap rate all weekend.
Having the delayed charge function is absolutely vital to take advantage of this cheaper rate.
My previous car had the timing function already built into the car, not the ZS EV of course, huge oversight.
The “Sonoff” gets around the problem.
Best £12 I ever spent !.
