Post your favourite joke! Keep it clean and PC!
I think this one is still topical :-
I really find it quite confusing
This electric fuel I’m using
I’ve used a Granny for a charge
Or a wall device, a bit more large
When out about and running free
A rapid charge is the thing for me
And I must admit it all works well
At least as far as I can tell
Performance doesn’t seem upset
Chugs along and not stopped - yet
But watts and amps and kilothings
I’ve not a clue, my brain just rings
If charging here or charging there
In a dark wee car park or anywhere
Are cheap electrons any good
In that inverter under the hood
Should I stick to solar power
Or off-peak stuff in witching hours
Or if it’s nuclear generated
Are its credentials overrated?
That guy in the pub the other night
Is it possible he was maybe right
It’s better made with oil or coal
Or were his theories up the pole ?
As he spouts misinformation
Use his hot air for generation
I’d only reached the halfway point
When the battery up and died
My red machine was down and out
Man, I could’ve cried
I recalled MG folks on the Forum
And the acronym spouted by them
“Calmly sit down, stop crying
And remember to RTFM !”
Well, I tried that, but no help at all
The battery cells wouldn’t waver
For these cells are not in the car
And I can’t FTM for the shaver !!?‍♂️
After many years of extensive and detailed investigation involving some of the best scientists in the world, the main cause of dry skin can be revealed:
Towels.
I’m often asked why we don’t have some way of extending the range of our journeys and, of course, I try to help and enhance the perception of our favoured mode of transport. So I try to help by showing the sort of ways we can mitigate any range anxiety as we’ve all been there and worried about these same issues in our pre and early adoption.
I distinctly recall dreaming up something like a trailer with a generator on it and went fairly far down that rabbit hole before two things happened.
One - I found that someone else had been and done it :-
Then two - it occurred to me that I might as well just go with the flow and have the engine in the conventional position under the bonnet.
Then I discovered someone had also sorted range anxiety in another way?‍♂️
