fred12345
I also didn't see any power draw from the Ohme but assumed it must just be using the battery.
The App confirmed the receipt of the instruction to turn on with a "Success" message.
I am now trying without the charging cable attached but has anyone got it to heat and draw power from an Ohme Pro and if so, what combination of pre-conditioning / scheduling did you use please.
It depends on how the things are connected inside the car, I would imagine that charging and discharging battery are two separate circuits and you cannot plug the car and have it use electricity from the charger and whatever the app tells you - success may be success in passing the message to the car, not turning the heating on which might be prevented from turning on whilst the car is charging/plugged in...
It works when the car is not plugged in?
