Random bong noise
We used to have an issue when Dino moved around on the back bench. Triggering the seat sensors.
Resolved by leaving seat belts plugged in all the time.
I’ve been trying to locate the random bong noise for a while, and what causes it, as it’s always baffled me.
After lots of time spent in the car with my partner paying more attention to the screen what we’ve concluded is it’s where the map has some form of road or traffic alert on its live data. It appears you don’t need a destination programmed for this bong to happen, and the “issue” isn’t always visible on the main map screen. However, when you do have a destination programmed you can sometimes see from the progress slider on the side some form of traffic alert symbol. The problem with this, is as soon as it’s bonged the alert “sign” disappears from view.
Certain type of traffic live alerts appear to bing a few hundred metres before, yet others like congestion seem to bong exactly where the slider shows.
Yes all shut not showing any red door warning. Also had tailgate tightened up as making rattling noises. Seems a common issue with many facing it
When you had the tailgate tightened, was it done via the bump stops ?
The reason I ask is that one owner had a problem with the tailgate not being closed properly (fully) was causing other problems (not going into drive was one IIRC) but no red warning on the dash to say it wasn't shut. I suspect that if the tailgate is being held very slightly open by the bump stops, i.e. not closed tightly enough, then it may be triggering the sensor and hence the beep.
School zones is one reason. And many others. Even with navigation off they will 'boing'. There are spots on the motor way where it boings and I really do not know why it does so. I ignore it.
School zone is a selectable option though. I have that turned off. Motorways are where I spend many hours, that’s how I worked out it seems to be road situation alerts (as indicated on the left hand side (UK) journey progress bar (when sat nav is programmed). When it’s not programmed, it still beeps, just 50% or more of the time doesn’t show on the map why.
I accidentally opened up the navigation page while parked at work yesterday and it instantly bonged to notify me I had entered the suburb. Which is fairly useless I would think, especially considering I wasn’t navigating anywhere.
Do you drive with the navi page open? Even when not using navigation?
Thank you everyone for all your replies and assistance. Think it is coming from sat nav even when not on.
It’s good to have all the support from the members.
Thanks again
Quite possibly as mine has started the random bong again. But it seems to have started since I updated the maps to the latest 24Q3, however it is more random than when it previously did it 🤷‍♂️
Just ignoring it now
My posts in a similar named thread
Annoying Blip Noise
Annoying Blip Noise
    Votes: 1,078 77.8%
    Votes: 208 15.0%
    Votes: 100 7.2%
