SimonS
- Jul 26, 2023
- Solutions
- 1
- Location
- Ayr, Scotland
- Not an MG
NB This is for the SE/LR in the UK. It may not work on other versions.
I've been plagued with the LKA randomly switching itself back on while driving. Also frequently when initially getting in the car, when switching off the LKA there is no 'Confirm' prompt and it does not switch off.
Previously I would unlock the car and get in, do up my seatbelt then wait for both screens to finish their boot up. I would then switch off LKA, switch on OPD, check the LKA icon is amber, then foot on the brake, select R or D and off we would go. At some point there after (could be 10 seconds, could be 20 minutes) something will trigger the LKA to return to 'on' and the icon would go white.
I have now discovered that if I change my start sequence LKA will behave as expected. The one change I have made is to put my foot on the brake BEFORE switching LKA off (i.e. door/sit/belt/brake/LKA+OPD/Drive). I then get the "Confirm" every time and LKA remains off for the duration of the drive.
If you have the same issue, give it a try.
