Hi,
I have searched the forum before posting but cannot see anything in the first few pages - so apologies if this has been covered.
I am currently looking for a new EV for my wife. I wanted to know what peoples experiences are of the MG ZS range in cold weather? The
MG ZS EV website reports Highway - Cold Weather as 95 miles. Is this accurate?
I do a 130 mile trip twice a year. The closest rapid charger is 96 miles away. If the reported 95 miles is accurate, then the car is not feasible (which would be a real shame) in the winter months, especially so, if I put a roof rack on.
Can anyone confirm what range they were getting last winter?
I've also looked at the MG5, but the boot space looks prohibitive for my needs - it's reported as: width 104cm depth 90cm which is too small.
Thanks in advance,
This is my first winter with MG ZS EV (gen1). So over the last two days, I performed a range check on my commute.
Here is the result.
Accumulated total from the trip computer,
Total distance covered: 98.6 miles
Avg kWh: 3.7
Avg miles/kWh: 24
from the home charger,
Energy used: 30.8 kWh
Actual average miles/kWh = 98.6 / 30.8 = 3.2
Using 3.7miles/kWh as the input to GoM,
GoM predicted range = 42.5 * 3.7 = 157.25miles ( 42.4 kWh being usable battery capacity)
Using 3.2miles/kWh,
Real-world range = 42.5 * 3.2 = 136miles
I attribute the drop (reported average kWh versus observed average kWh) to be the loss of energy for battery heating during overnight charging at home since this figure is not recorded by the trip computer when the vehicle is on standby.
On a long trip, I assume the range to be 60-70% of the real-world range. Charging performance on the rapid charger is best when charging from 20-80% of battery capacity. While you may start from home with 100%, you will most probably top-up to 80%( in some cases 90%) for subsequent charging sessions.
In the above example, I will assume a distance of 81.6 - 95.2 miles between charging sessions on a trip based on a real-world miles/kWh of 3.2. For clarity, my commute is on an A road, single carriageway, 23 miles, which takes me between 40-60 minutes on most days.
I should point out that the real-world miles/kWh will only drop significantly on highway runs especially in winter. I will risk a guess of 2.7 on a dry day.
Real-world range = 42.5 * 2.7 = 114.75
Assuming every charging session at 20%,
London-->Edinburgh journey will have for example at least 6 charging sessions, 91.8-----68.85-----68.85-----68.85------68.85-----68.85-----68.85
For this journey, I will advise you to take the train instead.
EV database predicts the worst-case highway range of 95 miles in winters. It works out to average miles/kWh = 2.23. I am sure that a day with wet roads, a lot of headwinds and near-freezing temperatures will return the suggested efficiency figure.
This will mean our London-->Edinburgh journey will have at least 7 charging sessions,
76----60----60-----60-----60-----60-----60
With practice and experience, you will in time be able to drive more efficiently and could expect to plan the trips much better. You will also be able to intuitively figure out if a trip will need you to stop for a charge without working it out on paper or using an app like zap map.
