Rolfe
Moderator
- Apr 10, 2023
- Location
- West Linton, Scotland
- MG4 SE SR
I've not seen anyone post a picture of this yet, so here's mine.
It's one of the 3D printed versions, which I got from CrawfyP as he had a couple spare. I don't know what it was printed with, so I don't know how well the material will withstand heat and light, but it's damn good for a first try and if it doesn't last then we know what to do - just use a better material next time.
It doesn't have these damn clips. It just slots in quite securely, seems very unlikely to move of its own accord, but should be relatively easy to get it out again if need be. I cut a piece from a polythene document holder to fit the inside of the top and tried to stick it in place with Superglue. Not sure how successful that was, but it seems to be doing OK for now. I might need to change it for a heavier grade.
I'm assuming it will perform just as the sensor did with no cover at all, because people who simply drilled a small hole in their cover said that worked fine so long as they got the hole in the right place. The uncovered sensor certainly behaves pretty much as it should do.
