Scheduled Charging
Ali8371
Cannock
Hi
Had my trophy model six weeks and car never seems to charge when it’s scheduled it will charge when I start it manually on the app
I have it scheduled on app and car but have read this shouldn’t be as it confuses it is this correct hope someone can help
Hi, what tariff are you on and what EVSE (charge point) have you got?
Can you set the timer on your EVSE and disable all car and car app schedules?
Hi I’m octopus cheap rate for electric cars I think mines not charging on schedule because it’s set on car and the app so I have turned the app off for scheduling and see what happens
Which Octopus tariff - there are more than one for EVs and as per previous post which EVSE (charger)?
Likewise we have an ohme charger with Intelligent octopus go, would be great to set it to gently (3kw) charge overnight (should i remove the CT clamp from the ohme?), rather than the aggressive 7kw, during the summer months where we just about have enough solar for house & car? - I've looked at different cars on the ohme app (currently set at ECC Fiat 500 (1949)), but I cant log into some of them including ohme (EV solar charging)
Can you change the car type in the Ohme app to one that can only take 3kW?
Also you can limit the car charge current in the charging part of the info panel? I don't know if the car remembers the setting, others may help.
    Votes: 965 77.6%
    Votes: 185 14.9%
    Votes: 93 7.5%
