Deleted member 14300
- Aug 24, 2023
I've never seen this before, but when you come off the throttle, the brake lights activate. I've never seen this before.
That’s your regen braking indication to the folks following you ?I've never seen this before, but when you come off the throttle, the brake lights activate. I've never seen this before.
Good point - but coasting equals no powered travel so friction and wind drag are going to degrade your speed at least to some extent so is it not better to alert those behind ??I wonder if it comes on immediately or waits for the car to be actually slowing continuously… for example if you lift off slightly on the motorway will the people following you get an instant brake light. Normal cars that coast, don’t have brake lights come on at all.
Weird, a quick read on my phone (so could be wrong) indicates that "emergency braking systems" don't need to put the brake lights on until 6 m/s² ?Anecdotally they come on when the regen % hits 7%. The actual answer is that they must come on when the retardation rate (how quickly you're slowing down) reaches/exceeds 1.3 m/s² (metres per second squared), but a manufacturer may choose for them to come on earlier.
More info for insomniacs here:
We live in a very rural area, with little light pollution, so yes, I wanted to test this, and it was easy to see when the brake lights came on in the rear view mirrors. I do not think it is related to percentage regen only, but mostly to actually slowing down. Having said that, on a very steep hill, where I did not think the car was slowing down, the brake lights were on - the car would accelerate under gravity without regen, so that must have been on percentage.Hello. If somebody tried to perform this test? When brake lights really switch on?
No, of course not. But if the brake lights come on at unexpected times, it could be seen as inconsistent driving, which can be dangerous. So I'd rather understand when the lights are likely to come on. It's just trying to be courteous.Who cares what those driving behind think? It's not illegal to have brake lights on when the car is slowing at any rate
