Tig170
- Aug 20, 2022
- Location
- Stratford-on-Avon
- MG4
Just new to home assistant: ours is
Nokia XR20.What phone are you on @securespark ? That app looks V different to mine!!
I didn't select the 100 Years theme, it must have selected itself, or updated or something.Look at the themes and select MG 100 Years and yours should look the same.![]()
You have lots to discover then!Just new to home assistant
Perhaps - but its not a main priority on the MG4.You have lots to discover then!
Wonderful! Now, if only they were believable.Car Scanner Pro also now gives individual pack voltages![]()
If those are your cell voltages then your car is borked.Car Scanner Pro also now gives individual pack voltages
Aye I’m assuming borkage is badSorry, that made me smile....I've never heard that word before.
No your maths are correct but I think the issue is that the car 'knows' its battery state whereas the Ohme estimates based on the car details it has plus how much it has supplied to determine percentage charge added. Also you must allow for measurement accuracies.It was more that the MG app was happy to state a full charge of 100%, yet Ohme says it still has 7% to go from a starting point of 5%.
Or is my maths up the creek?
Have I misunderstood?
That's odd. About a year ago I poked around trying to find sensible values for the MG4 using car scanner by looking at what was known for other MG's. I found some PIDs which looked plausible for battery pack values:Wonderful! Now, if only they were believable.
My guess is that they're not applying the right corrections (scale and offset) to the raw CAN bus data.
Deliberately ran mine down last night to see what would happen and with a view to doing a full balancing charge. Got down to 4%. GOM stopped displaying remaining miles at 10% ish and went into turtle mode at 5% and on the hill, I have to travel up to get home, I was gradually losing speed down to 20mph leaving both a squeaky bum and a feeling of total embarrassment. Fortunately there weren't many other cars around at the time but the thought of calling out the AA just 1/4mile from home due to a flat battery wasn't good![]()
I've been down to 4% a few times and never seen a turtle.
NMC cells have a typical operating range of 3.0 - 4.2 V.The voltages were typically 3.xxxx to a bit over 4 if I remember correctly. Is that in the correct range?
You winGot to 0% and the message ‘low charge, stop safely’ literally as I pulled up opposite the charging station.
Passenger was getting a bit anxious.
I was as calm as ever, as I know my GoM has always been absolutely spot on below 25% charge.
Turtle appeared at 2% charge left with 4 miles remaining.
At 0% it was still showing 1 mile left.
This was taken after plugging in for less than a minute.
bloody hell, I would not have been calm (but then when I was young and poor I did run out of petrol a lot)Got to 0% and the message ‘low charge, stop safely’ literally as I pulled up opposite the charging station.
I did a lot of walking with a fuel can too!bloody hell, I would not have been calm (but then when I was young and poor I did run out of petrol a lot)
